Xantia Rear Height Corrector Adjustment
Xaccers
x 188
Re: Xantia Rear Height Corrector Adjustment
Unread post by Xaccers »
CitroJim wrote:
citroenxm wrote: Ive VERY sucessfully corrected rear heights with the back on ramps and the front on the ground... Just look at it as though the car is on a hill! It works exactly the same...
Well, I don't know Paul but for me it's never been conspicuously successful but that's perhaps me. I hate adjusting height. Rattiva needs doing and I may well just throw in the towel and go and see Pleiades...
Or you if only you were nearer :wink: Maybe next time I'm in your Country... That's if they'll renew my Visa...
We need to organise a Finmere day :)
DIY sphere tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You can always put one side up on ramps or stands.
I often have two wheels on the kerb for under-car work as it gives both extra height and a margin of room for a quick but not planned exit!
x 8309
Xac wrote: We need to organise a Finmere day :)
Good thinking Xac :-D
We ned to organise a mass rideheight adjustment day :lol: My Activa could do with a tweak too..
addo
x 95
And everyone installs servomotor driven vernier adjustment to the height correctors with sync'd control plips once correct height is set.
Then, en masse, the cruising convoy magically rise and fall in perfect unison...
Xaccers
x 188
I'll talk to Tippy and hopefully there will be a paintball free weekend soon
DIY sphere tool
x 94
Unread post by citronut »
gadgetgricey wrote:
citronut wrote:
gadgetgricey wrote:Well turns out its going to have to be down hill, as only possess two ramps. :-D Dave -
if you are doing it with one pair i would think it will be better faceing up hill as this will make the car more level,
regards malcolm
I was actually referring to Paul's comments
Cheers all
- Dave -
yep i know i was just adding my two pence worth :wink:
regards malcolm
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I'm a bit lost with this talk of how difficult adjusting the ride height is and needing both end of the car up on ramps :?
As Paul states you only need to get whatever end of the car you are working on up on ramps, the other can stay on the ground.
Again as Paul states use the wheel arches to assess to the ride height, roughly three fingers clearance between the front wheel and arch, then the top of the back wheel roughly in line with the wheel arch at the back, simples.
To finely adjust the height, loosen the 11mm headed clamp bolt then with the engine running either pull down or push up the car to the required height and whilst holding it in position tighten the bolt, what's all this complication and fuss? 15 minute job including getting the ramps out and putting them back :?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Chris570
x 36
Unread post by Chris570 »
DickieG wrote:I'm a bit lost with this talk of how difficult adjusting the ride height is and needing both end of the car up on ramps :?
+1
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
chris... dickie... wow.. i was beginning to think i was the only one who found these easy cars to work on and setup.....
A very sad...
1994 XM 2.1 d auto
Xaccers
x 188
Remember, don't stick your finger in the wheel arch while you're adjusting the height! :)
DIY sphere tool
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
CitroJim wrote:Trouble is, without a pit or a ramp they're a devil to adjust.
Too true! Even with a ramp they are a complete nightmare.
I had mine on a mate's four poster and, I cannot remember exactly, but it seemed to take hours before I was satisfied that the front and rear heights were in spec. It is trial and error.
Now if you had the proper Citroen Tool - life would be a dream! As it is a long lever, you have the leverage to move the adjuster minute amounts. A useful tool to have. Not sure if anyone has one on the Forum.
DickieG
x 38
Now if you had the proper Citroën Tool - life would be a dream! As it is a long lever, you have the leverage to move the adjuster minute amounts. A useful tool to have. Not sure if anyone has one on the Forum.
Good lord if you were using that method no wonder it took so long, how many times did you under/overshoot the correct height? There's no need for a special tool to use that method as any lever that fits can be improvised.
I never use that method now as it's soooo hit and miss, try the one I described in my post above and get the job done in a fraction of the time.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
x 188
Definitely agree, I just pulled Cassy down to the right height, tightened the clamp and the job was done.
DIY sphere tool
gadgetgricey
Unread post by gadgetgricey »
DickieG wrote: To finely adjust the height, loosen the 11mm headed clamp bolt then with the engine running either pull down or push up the car to the required height and whilst holding it in position tighten the bolt, what's all this complication and fuss? 15 minute job including getting the ramps out and putting them back :?
At work at the moment so cant find the pictures on here for the Rear height controller.
Cant place the 11mm headed clamp bolt????
Two bolts hold the RHC to the cradle.
Three bolts hold the cradle to the Car.
Two bolts hold the bracket to the Rear Anti roll bar.
Off at three today so probably going to have time to look tonight, just want to get clear in my head what I'm adjusting.
15 mins, may be a bit optimisitc though :-D :lol: , but I'll give it a go.
cheers
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
citroenxm
Fallen Hero
x 70
follow the plastic clip dave to the anti roll bar clamp.. then the clamp it tightend with a single 11bolt... undo it slightly just to loosen it...
A very sad...
1994 XM 2.1 d auto
