Loked at a car with this problem, seller says it is just a small bolt missing at the front of the lever mechanism. I looked at mine and it could be right, no diagrams on my manuals.
Is this an easy fix ? Moving from low to high is ok, not much resistance. Won't hold in any position in between and just drops to low as soon as you sit in it. Just a missing bolt, or 'clutch' system if it has one not working ?
Thanks John
Height adjusting lever won't lock up
charentejohn
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
Old-Guy
- x 33
Re: Height adjusting lever won't lock up
Your Xantia is an S2 , while mine is an S1, but the height control leaver on mine is spring loaded downwards - you have to 'lift it out of a notch' to move it between in each of the 4 positions (and it has a strong tendency to return to NORMAL due to stickiness and the springs in the front and rear height control mechanisms.
Xaccers
- x 188
You're talking about the driver's seat aren't you?
Pull the plastic side panel off (upwards I think) and tighten the lever mechanism up.
DIY sphere tool
DIY sphere tool
charentejohn
This is a general position one with no fixed positions, on a Xsara but I can't take it to bits yet because I haven't bought it.
That said I will take a set of spanners with me and see if tightening the 'clutches' helps. Sounds likely but no reason why it should have a problem with only 24k miles on the clock.... Still, only a minor problem so if tightening is all it takes then no problem, as long as it stays tightened and doesen't keep weakining.
I had a car like that once for the reclining adjustment, about once a week I had to reposition it as it kept slipping backwards.
