Hello,
I changed my drivers side driveshaft at the weekend, I'm just a little concerned that when I pulled the driveshaft out I didn't lose a drop of gearbox oil! Not even a trickle. I did mean to check the level but the sleet kind of put me off!!! Is it normal to lose no oil? The box isn't notchy, everything selects as it should! But no oil loss!
Cheers Todd
Gearbox oil, should I be worried? C5 2.2 HDi
Millerboy79
NOW- Renault Megane Scenic RX4 52 plate! 1.9 DCi
C5 2.2 HDi P.O.S Shed on wheels! Ripped from the Citroen factory in 2001! With a manual gearbox! <<<<<<GONE!!!!!
- x 8115
Re: Gearbox oil, should I be worried? C5 2.2 HDi
It's not normal to loose no oil when swapping a driveshaft in a manual box but perfectly normal if it's an automatic 'box. They run 'dry splines' and have a different sealing arrangement to a manual box that run wet driveshaft splines.
In my experience manual boxes can survive for ages and ages on a very little oil with no symptom but will fail rather badly when under a heavy load, such as towing. I had a case recently where a Pug 306 TD wrecked it's gearbox spectacularly whilst towing another car over a distance of 90 miles. Until then it had been fine for months and months despite being almost dry.
If yours is a manual 'box then drain what's left in there as it will not be good and refill with the specified amount of new oil of the correct grade...
jgra1
- (Donor 2021)
- x 36
yep it's a manual
- x 8115
Then it's emptyjgra1 wrote:yep it's a manual
If so the reason will almost certainly be a failed driveshaft oil seal. They're cheap and easy to replace and they all use the same ones, MA, BE and ML...
- x 1435
Not forgetting that LH and RH seals are different....
- x 94
i spoz if you had the car upside down whilst swapping the driveshaft it wouldnt loose any oil
regards malcolm
regards malcolm
- x 8115
Yes it would, it would run out of the breathercitronut wrote:i spoz if you had the car upside down whilst swapping the driveshaft it wouldnt loose any oil![]()
regards malcolm
Millerboy79
I've decided I must have a peculiar car. I drained the oil out of the box, all 1.8 litres of it! And put the same amount back in. It didn't lose any when I changed the driveshaft yet it had the right amount in.
- x 8115
Well
There's bizarre! Can't explain that one unless you changed the driveshaft whilst parked nose-down on a steep hill
Millerboy79
I thought it strange! And it was up at the front drivers side when I changed it. The whole bloody thing is odd!!!!
