Fluid gathering
addo
Sara Watson's Stalker
x 95
Unread post by addo »
A calamari calamity?
Our man's copper washers could possibly be annealed for another crack at sealing properly.
KennyW
x 164
Re: Fluid gathering
Unread post by KennyW »
Guys,
I wish I never started speaking about bacon,squid and anything else =D> but it appears to be from the base of the injectors
It is NOT oil more like diesel.
SHMBO would be MINOR bit annoyed if I had to remove injectors to replace copper seals unnecessarily
It appears not to bad a job, HOW bad :?
Kenny
C3 1.4 petrol (SWMBO)
dnsey
x 19
Re: Fluid gathering
Unread post by dnsey »
Easy job to replace the seals, provided the injectors aren't stuck.
You're supposed to renew the pipe from the common rail to each injector, but IME there's no need if you're careful with the metal - metal seals when refitting.
KennyW
x 164
Re: Fluid gathering
Oh Dear the jokes go from bad to worse =D> but thanks for the replies
It sounds as though I'm going fishing for seals :wink:
Kenny
Xantidote
x 5
Re: Fluid gathering
Unread post by Xantidote »
fishing for seals
Enjoying the humour, but perhaps the post's title needs changing to suit??
Edit:- sorry, having problems with the "Quote"
Martin
x 8310
Re: Fluid gathering
Crumpets...
Xantidote wrote: Enjoying the humour, but perhaps the post's title needs changing to suit??
What to? 'Breakfast at Kenny's'?
Kenny, here's a diagram of the injectors showing the seal at Item 7...
KennyW
x 164
Re: Fluid gathering (How to cook in Xantia engine bay)
Thanks all,
Jim got the picture, £8 from dealers for 4 seals.
I have an injector removal socket which fitted the 1.9TD is it the same size
Kenny
x 8310
KennyW wrote: I have an injector removal socket which fitted the 1.9TD is it the same size
No, Kenny, the HDi injectors are not screwed in like the 1.9. They're a push fit and no pressure must be applied to the hexagon at all for risk of damage to the electrical bit of it.
Undo and remove the forked clamp and in theory they should just lift straight out. I believe there's a tool you can get that helps lift them out, a special pivoting lever that fits in where the forked clamp sits...
The injectors on the 2.2 can be a 'mare to remove but I've not heard the same applied to the 2.0. Sadly I have no direct experience of injector removal but others on here have and will no doubt soon offer advice.
Trouble is, I'm still a newbie on the HDi but learning fast...
KennyW
x 164
Re: Fluid gathering
Ditto, Jim :)
dnsey
x 19
Re: Fluid gathering
I recently replaced a couple of 2.0 HDi injectors, and they came out very easily - a slight rock with normal hand pressure, and they just lifted out. Hopefully, yours will be the same :)
I wonder why the 2.2 ones are so different?
KennyW
x 164
Re: Fluid gathering (How to cook on a Xantia engine)
Thanks for the Info Dnsy
KennyW
x 164
Re: Fluid gathering
Does anyone have the Bosch injector part No :?:
x 8310
Re: Fluid gathering
Kenny, the injector is Item 8 in the picture above. Only problem is I'm not sure what they mean by NE and ES Injectors and what the difference is. Not sure what they mean by Age =>2 either :?
Now they're the part numbers for 110 HDi injectors...
I'll go check if they are different for the 90...
x 8310
Re: Fluid gathering
Looks like the 90 engines shares the same injectors but has others too...
This from the bay of fleas. Gives a Bosch-like part number...
The Bosch part Number 9640088780 seems about correct after a few more searches....
DHallworth
x 165
Re: Fluid gathering
Unread post by DHallworth »
I replaced the washers on our Xantia HDi's injectors.
They lifted out without any problems at all :-D
There's also a little black plastic piece in there I replaced as well. All in all, not a bad job, expect it to be less then 30 mins to do them all. (As long as they lift out!)
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
