Hello
Nice to be here again. I have little doubt!!!
There's a simple way to know the condition of central Hydractive spheres? The bounce test on the corners is the suitable for themselves, but how to distinguish which of the three sphere per axle (hydractiva) is not in good shape.
I.e the corners spheres are very well, how can be noted that central sphere is wrong.
Regards
Bouncing test for central hydractive spheres
DickieG
- Monaco's youngest playboy
- x 33
Re: Bouncing test for central hydractive spheres
With the doors shut and igntion off for over 30 seconds push down on each corner then open a door and do the same push test, with the doors open the suspension should be softer.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Juliso35
Hi DickieG
A flat hydractive sphere could affect tick rate? This test you said should valid if height correctors and EV's are fully OK and non leaky right?
There is another way in case of failures in these two components? Just testiboules
Regards
Regards
DickieG
- x 33
A flat sphere will have some effect on tick rate as the sphere membrane will no longer have the ability to flex, how much effect a flat Hydractive sphere will have on the tick rate I couldn't tell you.Juliso35 wrote:A flat hydractive sphere could affect tick rate? This test you said should valid if height correctors and EV's are fully OK and non leaky right?
For the test to be effective yes the car needs to be at the correct height, if the electrovalves are stuck open or closed then no difference will be felt between tests.
I can't think of any other ways other than using a sphere pressure tester.Juliso35 wrote:There is another way in case of failures in these two components? Just testiboules![]()
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
