Activating cruise control C5
garrydog
Unread post by garrydog »
My car is a Citroen C5 2.0 HDI 2004.I have got and fitted the CC stalk , I have bought a Lexia 3, I have tried the Lexia on the car today all working well. On the Lexia the cruise control is switched on in the BSI ( I think )and i can see the C.C switch working on the Lexia ,I have been out and tested the C C but it is not working.
I think that the C C is not turned on in the ECU ,can anyone point me in the right direction to the relevant section on the Lexia to turn the C C on if it is present .
Thanks.
2004 C5 VTR 2.0L HDI hatchback.
Lighty
x 34
Re: Activating cruise control C5
Unread post by Lighty »
I always end up using trial and error, but I think you will need to go into injection ecu config and tell it the car has cruise
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
paulhelliwell2
Unread post by paulhelliwell2 »
Lighty wrote:I always end up using trial and error, but I think you will need to go into injection ecu config and tell it the car has cruise
It turns out you only need to enable it in the Injection ECU. I think the trick is that you have to let the car go to sleep after you have done it, i.e. lock it and go have a cup of tea. Come back and it works !!! :)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
There are two stages to enabling cruise, in the Injection ECU set 'RVV' to present then go into the BSI and enable cruise.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
garrydog
As you know I am very new to the Lexia ,I had a look this afternoon but in the ECU I could not find RVV ,what I would like to know is the step by step that I need to take in Lexia to find RVV , open lexia -------diagnostics------etc .
Citroenmad
x 110
Unread post by Citroenmad »
If you run the diagnostics operation, when the process is complete click on the injection topic, in there go to configuration and you will see a selection for cruise control.
Its a while since I did mine as it was on my previous C5, it took me a while to find it in the menus at first but that is roughly how its done.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
garrydog
Cruise control now working OK,thanks for all of your help you have all been great.
