Romie,
Delphi has the air con hoses connecting into the back fo the pump on a plate with 1 bolt through into compressor housing.
I think your belt is 1710.
I'll look at your photo's again to make sure
Kenny
P.S.
Romie your pump is sanden not a delphi, I try and find a photo of my compressor or I'll wait until SWMBO returns home from work and post a photo.
I take it this car has Air Con?
KennyW
- x 163
Re: I take it this car has Air Con? - SOLVED!!
C3 1.4 petrol (SWMBO)
romie
oops, opposite to what Xac said? :/KennyW wrote:Romie,
Kenny
ooohhhhXac wrote:Look at the backside of the compressor (ie not the belt end) where the solid pipes connect.
If they are individually held on by massive nuts, then it's a delphi harrison
If they go into a plate that is bolted to the compressor, then it's a sanden
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
Xaccers
- x 188
The pages showing 1726 would be why Cassy takes the 1725 as she's got the auto tensioner as shown in the top page (with the alternator).
Romie, because you've got a mix of the manual tensioner and the aircon in the auto tensioner position unless someone has the same set up we're really not going to be able to give you a definitive answer.
It could be that the car originally came with an auto tesioner (I don't know when they came in, Cassy has it and she's a '97, perhaps someone can do a RP number check) and some garage in it's past replaced it with the manual one and found a suitable belt to fit.
The only thing I can think of is either buy several belts, and match one to the current belt and take the rest back for a refund, or remove your current belt and take it into the shop to match.
DIY sphere tool
DIY sphere tool
Xaccers
- x 188
It's the same as mine which is a Delphi Harrison 1135253KennyW wrote:Romie,
Kenny
P.S.
http://compressor-express.co.uk/ac-comp ... -01-V5-PV8" onclick="window.open(this.href);return false;
Pipes connect with nuts
Then again I'm now finding sanden with the same number!
But it is shown here with the plate...
http://www.autoairparts.co.uk/citroen-x ... 4114-p.asp" onclick="window.open(this.href);return false;
DIY sphere tool
DIY sphere tool
Xaccers
- x 188
I'm finding both makes with both types of fitting, so perhaps that isn't the way to tell. It looks like either can be fitted with a different connector end to cope with either of the A/C pipe types.
DIY sphere tool
DIY sphere tool
KennyW
- x 163
Romie and xac,
My apologies Xac for suggesting you were wrong it would appear the difference maybe they can be changed with the Sanden version where as my old girl could not because of a different fitment
I am going to e mail tech services at delphi to find out.I have the following No's
1135253, 1135290 & 1135463 and will ask for diagrams if available or a manual which we can post on the site elsewhere
Kenny
Kenny
romie
Hi Kenny,
I know you weren't suggesting in anyway Xac was wrong
Emailing tech support at Delphi would be going 'above and beyond'! It would be great to get to the bottom of this.
I've got this whole weekend booked out for replacing both belts, changing the brushes in the alternator and welding on a new bottom bracket for the drivers side door
Looks like it's going to be a chilly, knuckle scraping couple of days 8(
Fingers crossed!
Fingers crossed!
Yamaha R1 1999 26k
Yamaha R1 1999 26k
DickieG
- Monaco's youngest playboy
- x 38
On the couple of A/C compressors I have in stock they both have manufacturer stickers on their side about halfway along, the trouble being that I believe the stickers will be on the engine side when they are mounted, must be worth getting out a small mirror and a torch to confirm what compressor is fitted.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
addo
- Sara Watson's Stalker
- x 95
romie
So here is the diagram of the sanden compressor.
When comparing the delphi diagram with the sanden one, the images I took from beneath my car seems to show more points that look like the delphi than the sandern.
Notice the 'ribs' going to the mounting points on the delphi diagram and on the actual picture of the one on the car. The sandern does not have these ribs.
Also notice the mounting points themselves. They 'stick out' much more like the ones on the delphi, but the sandern ones are a lot more squared off.
On a different note, it's odd that if Citroen go into their system via the 'compressor type' then there is only a choice of two belt lengths depending on compressor.
- No mention of the alternator?
But - If they go in via the alternator route then there are four choices of belt length depending on how many points the alternator is bolted on by AND THEN the type of compressor!!!
ugh... I've got to get something ordered to get to me for the weekend. Based on a 3 point alternator and that I've, (fingers crossed), got a Delphi compressor it should be a 1710mm 6 rib belt, order codes (5750P2), (6PK1710).
hmmm :/
hmmm :/
Yamaha R1 1999 26k
Yamaha R1 1999 26k
Xaccers
- x 188
That'd be really helpful Kenny!KennyW wrote:Romie and xac,
Kenny
Looking at the different compressors online that all proport to be the same model (SD7V16) but have different hose attachments, which would suggest that the pipes are not make specific as I though.
Those diagrams above show what Jim mentioned, with the pulley face being the important factor, especially as the Delphi Harrison diagram mentions screw union and union with clamp.
So triangular plate on the pulley = Delphi Harrison
Kool-aid man shape plate on the pulley = Sanden
DIY sphere tool
DIY sphere tool
romie
hahaha!
ok, I'll try to get to the pully front ;p
fingers crossed Kool-aid man isn't hiding there!
Heheh, many, many thanks - (in the words of kool-aid man himself), "ooh-yeeah!!"
Yamaha R1 1999 26k
Yamaha R1 1999 26k
addo
- x 95
romie
Re:
...would make me a happy worker as well! Think I've got to the last of the leaks that's caused all that muck last weekend. Just not enough time in the dayaddo wrote:A clean motor is a happy motor.
Trouble is other higher priorities keep getting in the way. Like the heating matrix has just failed, that's going to be another couple of days.. Having to use a towl to clear the INSIDE of the windscreen now. Am sure it's not good breathing in evaporated coolant for two hours a day on the daily commute to earn the cash to buy the parts to get me to work to buy the parts to...
~ sigh
If you have any suggestions on how to give that a good clean please let me know. That's a mix of engine oil, vegetable oil and LHM. I don't think Jizer water soluble degreaser will touch it - or my driveway. What you think? I spose it's not very sporting to bung it through an Asda car wash? :p
Thank you very much for the effort you put in to upload pictures of your compressor! I know how time consuming it can be!
Cheers! Romie
Yamaha R1 1999 26k
Yamaha R1 1999 26k
KennyW
- x 163
Hi Guys,
I'm back again
Check this link to the delphi tec site very interesting
Romie and Xac your pump number does not come up but the tech man at delphi says both the 5253 & 5290 are the same except the air con pipes are definitly diferent
http://webshop-cdn.tecdoc.net/delphi/?&isRedirect=1" onclick="window.open(this.href);return false;
I shall attach a photo of mine in a moment or 2.
Kenny
I'm back again
Kenny
