Post Reply
mg46783
My Cars:
Post by mg46783 »
<img src=icon_smile_dead.gif border=0 align=middle>
Edited by - mg46783 on 23 Sep 2002 01:35:58
gjb02
My Cars:
Post by gjb02 »
I'm no diesel expert, but I would seriously think about having the injectors checked. Each injector is setup to inject at a given pressure,(from the diesel pump) if the injector fails to open on time i.e. it requires longer to build up sufficient pressure to inject, it will effectively retard that cylinder by a few degrees. If two are out by a few degrees then you will get smoke, uneven running, knocking noises and poor acceleration. Get the injectors checked, it's normally free of charge, if they need refurbishing/overhall it may cost about £20 per injector. Just a guess, give it a go what have you got to lose.
Gareth
higgy
My Cars:
Post by higgy »
Sounds like your pre-combustion chambers have become loose, I think you need to take the head off to have a look.If its down on compression its going to have to come off anyway.
good luck
Dave Burns
My Cars:
Post by Dave Burns »
Agree with Higgy there, a bloke on here had exactly the same thing happen with a 306 td not long ago.
Unless of course it's direct injection, which I doubt.
Dave
mg46783
My Cars:
Post by mg46783 »
hi..just for info. I collapsed this topic 1, cos I sorted it and 2, cos , therefore I didnt want people wasting time on it - and 3, It wasnt a citroen !!!! ;-))) Thanks for your input those who did !
higgy
My Cars:
Post by higgy »
Glad you got it sorted,what was the problem?
mg46783
My Cars:
Post by mg46783 »
Hiya
ok, basically, big ends.... etc etc etc.... you can probably guess the rest from a very well choreographied course of events !
Post Reply
