Whats this bit??
Allante666
Whats this bit??
Unread post by Allante666 »
Hi,
Just half way through a clutch change on my Mk1 Xantia SD and as I was getting it propped up I noticed this on the exhaust manifold. What is it?
Also, whats a 'sinking xantia' and a 'anti sink' one?
pic:-
Citroenmad
x 110
Re: Whats this bit??
Unread post by Citroenmad »
Im not sure, looks like a typical clutch adjustment?
A 'sinker' is a Xantia without anti-sink, the car will sink to its low suspension position when parked for a while. A car with an anti-sink valve will keep its suspension level at normal ride height.
Is yours a sinker or an anti-sink model?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Allante666
Whats this bit??
Clutch? Its on the exhaust manifold! I was guessing that it was some sort of valve to divert hot air to the inlet etc. it's where I imagine the turbo would be if it had one. Just thought it looked complex for a diverter valve. Sink? When I leave mine overnight the back end just sinks maybe a couple of inches that's all. Does that make it an anti sink?
I am here: http://maps.google.com/maps?ll=53.338671,0.262063" onclick="window.open(this.href);return false;
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Looks like an ordinary wastegate on a turbo engine, to me?
x 8318
Re:
addo wrote:Looks like an ordinary wastegate on a turbo engine, to me?
Excactly, it's the wastegate and wastegate vacuum actuator...
It's oily which suggests one or other of the inlet pipes is a bit loose/leaky and may be leaking off a bit of boost... Else thet, check the pressure lubrication feed and return pipes to the turbo for leaks.
Allante666
Whats this bit??
Hmm. My point being however that this is an SD. I thought the SD was non turbo?
Xaccers
x 188
Unread post by Xaccers »
Allante666 wrote:Hmm. My point being however that this is an SD. I thought the SD was non turbo?
Later SD's had a low pressure turbo.
Sinkers were 93-94, one or two may have been registered in 95
DIY sphere tool
x 5659
My "N" reg (95) was a sinker with the chevron on the bonnet.
Dommo
x 20
Unread post by Dommo »
It just doesn't ave an intercooler like turbo d engines. It has the turbo though clearly
Allante666
Thanks all, thats answered those bits. Have now finished fitting the clutch, just need to wait for all the cuts and scratches to heal now!
