Hi folks
I have seen a cheap 406 Hdi non runner, says 'faulty BSI unit' I know nothing, can anyone enlighten me?
BSI chip?
Citroenmad
- x 110
Re: BSI chip?
The BSi unit is the computer which controls the electrics, its part of the multiplexed system.
Apparently they can be repaired or reset:
http://www.bba-reman.com/content.aspx?c ... ol_failure" onclick="window.open(this.href);return false;
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
Re: BSI chip?
Thanks, what does replacement involve? Sorry, missed the link
benzema
Re: BSI chip?
eBay is quite a good place for a replacement BSI unit.
Keep an eye out for some listings, it may surprise you.
Lighty
- x 35
Re: BSI chip?
The BSI contains the coding for the immobiliser, so a used one cannot be fitted unless it is made blank, or the engine Ecu is de mobilised , ie removing its security.
When you it a new one, you have to program the vin no into it, the configuration of all the electrics, ie if it has electric windows, AC etc etc, and then you program in the keys, and the car should start.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
