Hi v6 owners...
I have an ongoing issue with my old v6.... Which the current owner is still having. The car has a cold engine missfire which does clear when warm and doesnt come back till very cold again.. Ive fitted plugs and an inlet gasket when i had her.. Now the new owner has apparently tried two coil packs to no avil.. She still does it for him... So i guess we need a lexia session.. How ever i could do with some info like parameter readings from someones healthy v6 so i can compare..
So anyone with a P or R reg mk.1 v6 and a lexia who can take down the two screens of live parameters for me?? You dont have to write anything down.. A mobile phone camera takes a good enough picture if it has a good camera..
Heres hoping
thanks
paul
xantia v6 info needed...
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
Re: Xantia v6 info needed...
It doesn't need to me a MK1 Paul, the MK2 uses exactly the same injection and ignition..
I can do the honours for you tomorrow if you wish but it'll be on an early MK2...
jgra1
- (Donor 2021)
- x 36
Paul, bizarrely I think I may have some of that...
bear with
bear with
jgra1
- (Donor 2021)
- x 36
https://picasaweb.google.com/1043108896 ... 4252598370" onclick="window.open(this.href);return false;
https://picasaweb.google.com/1043108896 ... 2303553282" onclick="window.open(this.href);return false;
any use?
I have never really used a diagnostic machine ..
any use?
citroenxm
- Fallen Hero
- x 70
Thats a start John, but for a Pug 406... Is that an early 406 or a later VVT one?
I could ideally do with COLD START readings, as the engine is fine when warm!
Thanks for those John.. Ill load them to my phone and keep them handy..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jgra1
- (Donor 2021)
- x 36
same engine as yours Paul, non vvt..
I may have some more, but I may let Jim or others take over from this point
HNY
HNY
citroenxm
- Fallen Hero
- x 70
Ok John, cheers much appriciated..
Paul
HNY to you too!!
Paul
HNY to you too!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
And HNY to you Johnjgra1 wrote: HNY
Yep, I'll do but can't right now as mine is still hot after a blast to Somerset and back today....
With Lexia3 I should be able to capture the screenshots electronically rather than take screen photos. We'll see...
citroenxm
- Fallen Hero
- x 70
Ive got Lex 3 Jim, but not seen screen shot capture....
Much appriciated Jim.. Thanks
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
Hi Paul, this is my V6 cold and just after startup..
Injection Information:
Ignition information
Sensors:
And finally, driving parameters although the car was not moving at the time...
'Fraid the engine warmed a bit whilst this was going on.
Don't forget that even from just off ciold the Oxygen Sensor will be cyclically varying between about 100mV and 850mV.
Hope that helps...
Sensors:
Hope that helps...
citroenxm
- Fallen Hero
- x 70
Okay jim thanks.. That looks great.. Ill need to pinch it now and put it on my phone for reference.. If thats okay??.
Thanks fir dooing that.
Happy new year.
Paul
Happy new year.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8457
No worries at all Paul, you can do whatever you need with them!
I trust they'll help you correct the problem...
