Genuine new Xantia strut top on eBay
davewithington
Unread post by davewithington »
This must be of use to someone at this price,
http://www.ebay.co.uk/itm/NEW-GENUINE-C ... 415fbdfd99" onclick="window.open(this.href);return false;
x 8343
Re: Genuine new Xantia strut top on eBay
Good find Dave and it's a Hydractive one too :-D A steal at the price. That one won't hang around long :)
Dommo
x 20
Unread post by Dommo »
SOLD to the man in the skirt...
Cheers Dave, I've been after a nearside one since October 2010!
x 8343
CitroJim wrote:That one won't hang around long :)
Told you :lol:
Dommo
x 20
At that price I'd have considered it even if it were an offside one which I don't need.
Should anyone require an offside/drivers side non hydractive strut top I have a very near new spare.
davewithington
You've had it then Dommo?
I did think of you in passing, after I've posted the thread
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Dommo wrote:At that price I'd have considered it even if it were an offside one which I don't need.
Keep it dommo! Get it coverted when you need it.. Theres no difference between normal and hydractive tops other then the larger pipe fixing.. So all that needs dooing WITH CARE is drill the small hole out to a larger size and tap it out to the size of the larger pipe... They are easy to drill as they are not hardend...
I know its possible ive seen it done and it worked sucessfully.. I cannot remember the drill and tap size just now but will get it.. This then means its good to collect good 3.5 mm tops they can then be used as either with a bit of simple modification...
Paul
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
Unread post by Chris570 »
yep i've had it done, hence i have a perfect set of s2 hydractive strut tops waiting for my activa should the time come
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Ah nice one chris.. Thats two backups ive got now... Nice one.
Paul
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
picked up a set of tatty ones from that TCT as well, perfect candidates for refurbishments when i'm ready ;)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Dommo
x 20
I have bought it Dave, not arrived yet though. I had considered drilling and tapping the thread size to be a bit larger, if it were a nearside one I'd have done that long ago however I've effectively got two offside ones so I don't need it drilling out just yet.
Dom
x 94
Unread post by citronut »
are you sure the strut ram is not a diferent diamiter H/A to non H/A were it fits into the strut top,
regards malcolm
citroenxm
Fallen Hero
x 70
Nope... I beleve its only v6, 2.1, and activas with the larger struts... All others use the same diameter pistons....
Paul
A very sad...
1994 XM 2.1 d auto
x 8343
citroenxm wrote:Nope... I beleve its only v6, 2.1, and activas with the larger struts... All others use the same diameter pistons....
Paul
I believe it's only the V6 that has the thicker struts... I'm pretty sure the Activa has the standard ones but not 100% dead sure on the 2.1 and 110 HDi
x 94
i also thought i had read somewere the early cars had a diferent size strut shaft that later ones,
regards malcolm
