Ok, since the Xantia was crashed into ive been somewhat on the fence as to wether to carry on fixing it up or to bide my time and then shift it and get something else......I cleaned it up the other day and decided it is still a great car so im going to fix it back up
Ok....i need to get the dashbulbs done but firstly need to tackle the negative battery terminal. Its knackered. Last night i got into the car and waiting for the glow plug light to go out. Whern it did i turned the key and everything went dead...the CD spat out and all power was gone. I got out, shut the door, locked it and unlocked it with the key and then everything was back normal again and i drove home. Straight away i thought...earth problem somewhere.
Today i have checked the battery negative and its very loose although its bolted up. The problem is it has been repaired in the past and the bolt when tighted as much as possible has started to cut through the body of the terminal. This means i cant tighten it up any further or it will break. Whats the best way to fix it? Im cant just hack off the terminal and put one of those bolt on jobbies as ive been told in the past it would involve removing the complete negative lead which in itself is a big job?
I was thinking to get a second hand lead of anotehr Xantia and swapping it over....anyone done this or have any other ideas?
Regards
Vince
