VSX Turbo TC advice please.
Stepto1
Unread post by Stepto1 »
Some of you may have seen a green VSX Turbo TC recently for sale on this forum. Well I wen ahead and handed over 300 quid for it and a boot FULL of spares!
My concern is this. It's quite a bit rougher then discribed. I knew it needed a new wing and general tidy up but it also needs:-
The other wing.
Bonnet.
Rear door.
Tracking doing. (pulls like mad and doesn't track straight. Accident damage).
Indicator stalk changing.
Air filter mounting. (Currently secured with a bit of net curtain).
Front and rear height correctors not working right. Think the rods to the antiroll bar have been damaged.
Hydractive doesn't appear to work.
AC doesn't work.
Heater/rear window not working. (knew about that).
Doesn't always go into reverse.
Smells of fags.
What should I do? Is it worth spending time/effort/money on?
Steve.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
citroenxm
Fallen Hero
x 70
Re: VSX Turbo TC advice please.
Unread post by citroenxm »
Apart from the body items, most of those listed are the useual "Xantia Weakness" Parts and are common failiures...
The heater and rear window is likely the ignition switch, in which its needing the Relay Mod dooing..
Height correctors could also be just siezed linkages which are a huge common problem.. but freeable with time..
ASSUMING it has a BE box, and is not an ML box. Most BE gearboxs have a "selecting Reverse" issue, I find with the clutch down goto 5th first then striaght down to Reverse and they useualy go everytime...
Indicator stalk - Theres S1 stalks and S2 stalks.. S1 stalks have the horn on the end.. S2 ones DONT... they look identical though.. useually around 30 quid...
Paul
A very sad...
1994 XM 2.1 d auto
x 1485
1. Rip the egine out and sell it to the Saxo / 106 brigade.
2. Weigh the rest in.
3. Buy a decent HDi :lol:
1 and 2 will probably pay for the original outlay. 3 will save you a small fortune in reduced fuel useage!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Bit of a mission, by the sound of it. How does the underside look on a hoist?
Minor collision damage can usually be pulled out by a skilled panel shop without the need (especially in a low budget environment) for lots of dismantling/repainting. However a lot of people can't be arsed with this; as a result the geometry is always a compromise.
Stepto1
Thanks for that guys. It's got an LPG kit and does pull like a train. Even with a bootfull of spares it pulled away from 70mph with no problem in 5th on gas! It's had a leather interior fitted too. The engine is said to have been remapped and a non standard ECU fitted.
robert_e_smart
x 14
Unread post by robert_e_smart »
Scrap it.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Stepto1
Right. Had a look over it again today and it's a shed. Does anyone want anything off it before it goes for scrap?
citroenxm
Fallen Hero
x 70
Leather good??
Paul
A very sad...
1994 XM 2.1 d auto
Stepto1
Black leather. Looks good. Not electric. In Nottingham or Plymouth.
citroenxm
Fallen Hero
x 70
Okay.. Nottigham would be better... How much?
Paul
A very sad...
1994 XM 2.1 d auto
Stepto1
Open to offers. PM me. I'll throw the steering wheel in too!
Chris570
x 36
Unread post by Chris570 »
LPG kit
seriously, i'll come up and strip bits off, where is the car?
and the ecu, i want lots....
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
Stepto1
I'm near Nottingham.
LPG kit. Can be seen working. Tank replaces spare wheel.
ECU. Standard and chipped/mapped ECU (200bhp the seller said, it is quick)
Loads of spares, what do you need?
Steve.
Chris570
x 36
i need the LPG kit in its entirerity
what ECU is it? might want the wiring loom as well.....
how much?
as said i'm more than happy to strip bits off myself if that's easier?
can you PM me your postcode?
Cheers
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8343
Oh dear. Sorry to hear this Stepto.
I see the vultures are circling :roll: There's nothing I can think of my Harris Hawk wants. If it had been a very late MKII 110 HDi then it would have been a different story...
Chris, You may need the ECU if you plan on having the gas kit. They may be inter-linked.. I'd have it all quite frankly...
