XM V6 Gearbox Rebuild...
Chris570
- x 36
Re: XM V6 Gearbox Rebuild...
with any luck the next 8 days should see the engine back in the bay......
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8334
Well, it won't be the gearbox holding the job up ChrisChris570 wrote:with any luck the next 8 days should see the engine back in the bay......
It went smoothly except for a need to make an emergency visit to Halfrauds this morning. My T27 Torx bit decided to crumble to nothing and I needed to get a replacement quick. T27 is an odd size and locally only Halfrauds stock them. I was there for doors opening...
I must admit the Torx bit in question had been terribly abused on another gearbox, even ending up in my impact driver at one point to shift a particularly tight one. I'll forgive it for throwing in the towel...
The rebuild took a full day although a good deal of that time was cleaning until everything sparkled. I take my time reassembling as any errors would require the engine to be lifted and I'm not too keen on that
No pictures from today but this picture sequence from one of my previous rebuilds covers it pretty well...
Chris, come and collect at your leisure
Deanxm
- x 87
another job well done Jim
Dont know what that Chris is playing about at, should be driving home in it for christmas no problem
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8334
Well yes, He's done all the other work whilst I had the 'box so all he needs to do is pop the engine and box back in, plug a few connectors together, fill up with coolant and job's a good 'un... If it takes more than a day I'll be disappointedDeanxm wrote: Dont know what that Chris is playing about at, should be driving home in it for christmas no problem![]()
I must say doing an engine out job on an XM is a joy to behold. So much easier than a Xantia
Deanxm
- x 87
XM Prestige PRV6 92
robert_e_smart
- x 14
Jim has finally seen the light!!!CitroJim wrote:
I must say doing an engine out job on an XM is a joy to behold. So much easier than a Xantia![]()
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
1991 BX 16 TGS Auto
Deanxm
- x 87
yep none of this lifting engine first on its side and over the slam panel rubbish, just unhook and wheel it out forwards, that hdi thing should have been a 2.1td xm hatch.........................
D
D
XM Prestige PRV6 92
Chris570
- x 36
who said it won't be!!!Deanxm wrote:another job well done Jim![]()
D
I'm aiming at ICCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCR for the car to be running so I'm not too fussed. In all seriousness I don't want to rush the job because there's so many things I want to get right first. I also don't want her on the road until the weather improves as if she's driveable I suspect I'll be tempted. There is also the little matter of strut tops to contend with so that will all take time.
The original plan was to have the engine back in by the end of jan/mid feb so we're well ahead of time here
But, Mr Jim, BIIIIIIG thank you, I have popped a little (well big actually) present in the boot for you. If you're extra nice I might pop it round to you tomorrow
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
robert_e_smart
- x 14
I told him he should buy a 2.5 TD Xm! Our Jim likes a challenge!Deanxm wrote:yep none of this lifting engine first on its side and over the slam panel rubbish, just unhook and wheel it out forwards, that hdi thing should have been a 2.1td xm hatch.........................
D
1991 BX 16 TGS Auto
1991 BX 16 TGS Auto
