MOT Failure - Handbrake Efficiency 11%
mirafioriman
Re: MOT Failure - Handbrake Efficiency 11%
Well unless the regulations have changed its 25% for single systems and 16% for dual systems so 11% should have been a fail.
Just checked online and it's still saying 16% for dual systems so looks like the tester didn't know the rules!
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
citroenxm
- Fallen Hero
- x 70
Xsaras like most lesser cars with servo brakes have a load sensing valve on the rear.. Common for siezing up...i guess its connected to the anti roll bar simmilar to the roll bar clamp on the xantias
paul
paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DHallworth
- x 167
If the Xsara is like the 306's at the back then I suspect the estate might have a load sensing valve at the back so if the cars empty it's not putting much pressure on the brakes.
I'd chuck 4 or 5 bags of sand in the back and take it for a spirited run using the brakes a lot and see if the disks look any cleaner/shinier when you get home first of all.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
handyman
Yep, Davids hit the nail on the head. As the brake bias is always on the front of these lightweight cars, its always worth putting some deadweight in the boot at MOT time. If everything checks out mechanically with your rear brakes, leave some weight in the boot when you go for a retest. I always put in two bags of cement in the boot of the ZX at MOT time, its yet to fail on rear brakes.
If you are not sure about changing joints, leave well alone unless you have somebody experienced looking over your shoulder and you have the right tools to undertake the job, ie splitters, etc.
Handyman
Handyman
dandare1980
The rear load sensing valve had seized on my other car, a Mk1 Xsara, the last time it went in for MOT. Managed to free it with a bit of lube and it passed ok.
I will certainly try the weight in the boot trick and will check the rear load valve for operation.
My wife's Xsara doesn't run up the mileage and she carries little weight, so think it may be worth taking it for a drive with some weight on board like people have suggested.
Thanks for your comments, got to start on the track rod ends in a moment, if I don't get blown down the street first by the wind........it's terrible today
Dan.
Dan.
1998 Citroen Xsara 1.9 D Estate (XUD9A indirect injection engine DJY with Bosch XUD 211 injection pump).
- x 8378
dandare1980 wrote: if I don't get blown down the street first by the wind........it's terrible today![]()
Not been good has it
All this talk of a compensator valve might be a red herring if the footbrake test passed OK at the back - or have I missed something? It'll make no difference to the handbrake efficiency...
Malcolm, you make a point that the handbrake mechanism must release fully to allow the automatic adjusters to work. Presumably then, if the cables are tight or seized then the mechanism can never fully release and this the automatic adjustment fails to be made...
- x 94
this seems to be the case with all hand brakes on disc brakes as far as i have seen,CitroJim wrote: Malcolm, you make a point that the handbrake mechanism must release fully to allow the automatic adjusters to work. Presumably then, if the cables are tight or seized then the mechanism can never fully release and this the automatic adjustment fails to be made...
regards malcolm
addo
- Sara Watson's Stalker
- x 95
dandare1980
Ok, just got back from my father-in-law's (self employed mechanic who prepares rally cars).
Handbrake cables appear fine, disconnected them at the caliper and at the handbrake lever and they both move freely.
The levers on the rear calipers both appear to travel through their entire range and do not appear to be sticking.
We've sanded/cleaned up the corrosion on the discs/pads and refitted them. The discs are flat with no pitting and the pads are in good condition so my father-in-law couldn't see what fitting new ones would achieve.
After readjusting the hand brake mechanism, the brake is operating better, but not great. I can still pull off with the handbrake fully engaged.
It will now hold me on steep hills, but has little effect at slowing the car down if applied whilst travelling at around 15 mph.
I just hope to hell it's enough to get beyond the 16% required efficiency at the MOT retest tomorrow.
If it still can't pass, what options am I left with? Will I need new calipers?
Thanks again for all the input.
Dan.
Dan.
artdjones
It's hard to check whether handbrake cables are ok or not.They can be free when disconnected but seize up under load.I generally check the calipers first.With the cables disconnected from the caliper you can attach a set of grips to the lever on the caliper the cable attached to.Then try to turn the hub with a long prybar between two screwed in wheel boltswhile pushing the caliper lever towards the front of the car with the grips.If the hub is locked then the caliper on that side is ok.If both calipers are working ok then that means cable problems.
- x 94
i would ask the MOT station if they could run through the brake test before loging onto VOSA's computer as a retest,
because if it still fails to meet the requirements you will still have you one free re/test up your sleave,
that is unless mpore than ten working days not including bank hol's and weekends have elapsed,
how did you adjust/reset the callipers up this time,
regards malcolm
regards malcolm
dandare1980
Thanks for your replies.
We set the rear brakes up according to the Haynes manual, so in short once the pads and discs had been replaced (locating the lug on the rear of the inner pad with the piston slot), foot brake pressure was applied to bring the pads and discs into contact.
We then re-attached the handbrake cables to the caliper levers and began to wind the adjuster nut under the handbrake lever back in until a slight drag was being felt on the first "click" of the handbrake's ratchet.
The handbrake seems to be holding better, but of course no way of knowing the exact efficiency. The foot brake seems better too (could be the placebo effect though).
I did enquire when it failed as to whether they could run it on the rollers first before taking it through the test, to save me failing the free retest. However, the guy I spoke with didn't seem to think this would be possible as, in his words "once we've logged onto the machine......" I don't think they were feeling cooperative that day.
Got my tracking done at National yesterday in Northampton after doing the track rod ends (£15 on special offer, voucher on their website valid until Apr 2012). Asked them if they could test the brake efficiency, which they can no problem, it's £20 though.
One thing I noted, but couldn't really tell from the Haynes picture, was how far the lug on the rear of the inner pad was meant to be seated within the piston slot? On the old pads currently fitted (cheapest from Central Auto Supplies), the lug seems to be more on the outside of the piston slot than within it. Could this be causing an issue?
Also, what is the purpose of the anti-rattle clips? They seem to hang loose and not really do a lot apart from get in the way on refitting?
Got to take it through now as MOT due to expire. Will post back on results, fingers crossed!
Thanks again,
Dan.
Thanks again,
Dan.
dandare1980
Hooray! It's passed the MOT!
I didn't get a brake efficiency report, but the handbrake was obviously scoring high enough that it passed the 16% limit and was good enough that it was not picked up as an advisory.
Thanks to everyone who has helped me with suggestions and advice throughout this post, the information has been informative and has saved me money.
Dan
Dan
jgra1
- (Donor 2021)
- x 37
- x 8378
Dan, that's excellent news
Just the heater matrix now
