As above does anyone know if a 2003 2.0 c5 hdi gearbox has a fill level plug on the gearbox or is it just a
case of filling with the specified amount of fluid.
I have found the drain plug and am guessing the box is just filled via a breather on top but i cannot find
a level plug, i believe it is an ML5 box, any pointers gratefully recieved,
cheers sam
c5 gearbox level plug
411514
- (Donor 2017)
- x 40
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
VertVega
- x 13
Re: c5 gearbox level plug
It took some time to "dig" this pic. from archives
Finally found it under the year 2008 album
The blue circle shows the filling plug (Thanks to RichardW
I always use the breather plug for filling. 1.8 l is the official amount, I simply pour down 2 x 1 liter.
- x 1485
There is one i think - but it's on the back of the diff somewhere (god only knows why!). Easiest just to drain then refill via the breather or reverse light switch with the right amount of oil - use ONLY 75W80 - and preferably TOTAL BV stuff
- (Donor 2017)
- x 40
Ta for the pic vert vega, i probably missed the level plug as it looks the same as the other fixing bolts, if not il just have to fill with the specified amount
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- x 1485
I'm pretty sure that pic is wrong VV - service.citroen just shows that as on ordinary bolt with no seal behind it - whereas there is 'Casing plug' (with seal) on the back of the diff - it's probably the one shown sticking out with a bigger head just up and right from the drain plug you have highlighted red. Which is is why it's impossible to get at with the 'box in the car
- x 2941
This is the ML5T box.
VertVega
- x 13
Thanks RichardW, updated the above message and adding this pic. below.RichardW wrote:I'm pretty sure that pic is wrong VV - service.Citroën just shows that as on ordinary bolt with no seal behind it - whereas there is 'Casing plug' (with seal) on the back of the diff - it's probably the one shown sticking out with a bigger head just up and right from the drain plug you have highlighted red. Which is is why it's impossible to get at with the 'box in the car
I hope 411514 will also notice this message
So it's the #16.
411514
- (Donor 2017)
- x 40
Yeah cheers vv & gibbo, iv spotted it, looks like maybe il just have to fill with the specified 2.1 litres, that level plug looks pretty inaccesible, cheers sam
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
