Had to be recovered by the AA today , the dispatch (2006 2.0 hdi 8v) cut out in the middle lane so I coasted onto the hard shoulder , tried restarting it but not a hope , the AA man said there's fuel in the filter and says it's a fueling issue , has anyone any ideas and potential costs etc , thanks
Mark
HDi won't start , help
bxzx16v
- x 34
DickieG
- Monaco's youngest playboy
- x 33
Re: HDi won't start , help
I presume a Dispatch has a pump in the fuel tank so can you hear it running? Turn on the ignition without starting and you should hear a faint buzzing for about 5 seconds.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Carsten S
Also check the "kill switch".
It normally located near the firewall. You can reset the switch by pushing it.
bxzx16v
- x 34
Thanks I will go and have a look now
Mark
Mark
bxzx16v
- x 34
It's none of the above , the fuel tank pump is buzzing as described & the kill switch is ok
Mark
Mark
DickieG
- x 33
In that case I think your next port of call will be a Lexia session. I take it the timing belt is OK with the engine turning over normally?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
bxzx16v
- x 34
Yes the timing belt is fine , the AA patrols diagnostic wouldn't read fuelling etc . A friend works for Peugeot so he's going to plug his diagnostic in and see what it throws up . Been told that with it being a very late 2.0 Hdi 8v the pumps a very good so I'll have to wait and see. Will post up the results. Thanks
Mark
Mark
bxzx16v
- x 34
Just got the diagnosis for the Hdi dispatch , it looks like possible waterpump/pulley problem as part of the timing belt is shredded , I've been told to strip and inspect the water belt/pump etc and try another timing belt as I may (very doubtful) have got away without any damage ????? Anythoughts on this please
Mark
Mark
lexi
- x 133
Must have jumped a tooth?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 1490
The HDi is an almost safe engine - timing belt failure just breaks a few rockers. Whip the rocker cover off and have a look for any broken ones. If there are none, then you will probably get away with just fitting a new belt etc. If any are broken, then you will need to replace, and fit new belt. Either way should be recoverable - but the rockers are not that cheap....
bxzx16v
- x 34
Been told that the rockers are about £25 each , I'll keep you posted on the progress ,thanks
Mark
Mark
electronmirror
- x 30
Mark,
There are several sources on ebay selling rockers for the Hdi engine. Prices seem to vary between £8 and £15 depending on which engine it is.
Your quoted £25 sounds like main stealer price.
Ted
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
wotwot
- (Donor 2021)
- x 4
Hi only posted to see the outcome.Cant find a subscribe button
Maybe getting an HDI dispatch in the future so interested to see they are a (fairly safe engine).
bxzx16v
- x 34
Thanks for that Ted I'll have a look for some , a friend of mine who works for Peugeot and previously Citroen will be starting the job in a couple of weeks , depending on price etc
Mark
Mark
- x 5672
The leftmost small icon at the top of the page - looks like book pages with a green dot on.wotwot wrote:Hi only posted to see the outcome.Cant find a subscribe button.
