XM V6 Gearbox Rebuild...
x 8263
It's started :-D The first work toward refurbishing Chris570's XM V6 gearbox has begun..
First job was to hoist it on the engine crane and give it a good wash after removing many ancillaries. here it is fresh from its bath:
I was hoping Chris was going to bring it to me sparkly clean but alas, no such luck.
And here it is all ready for the taking apart...
I already know one problem and that's the oil filter; it's as blocked as a blocked thing. I found out when I removed the cooler and oil gushed out from the main gallery from the pump. By now that gallery should have been empty - having drained back via the filter.
Another dead give-away was little oil in the torque converter and no oil running out when I tipped it on end just before I took the second photo. A good one will fairly gush when tipped on it's side like that...
The torque converter neck bearing is good and as it was not noisy when it died, or not excessively so, I'm hoping that it's not badly damaged.
More news as it happens...
Chris570
x 36
Re: XM V6 Gearbox Rebuild...
Unread post by Chris570 »
:D :D :D :D
Thanks Jim
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Its amazing the things some people get up to in their lounge :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Chris570
x 36
DickieG wrote:Its amazing the things some people get up to in their lounge :lol:
Well for the amount of time that Jim spends in there (hiding from the police) it pretty much is his lounge
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8263
:rofl: :rofl:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'm waiting for the next instalment. Sort of wish I had one to play along with.
What's a rebuilt converter cost there?
Deanxm
x 87
Unread post by Deanxm »
About £100 is the norm last time i checked for a reconditioned unit.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 8263
Deanxm wrote:About £100 is the norm last time i checked for a reconditioned unit.
D
Who was that with Dean? Mackie Transmissions in Glasgow?
addo
x 95
That's a very good price by our standards - probably cheaper than local by a margin exceeding freight cost. Might hit them up for an Aisin Warner unit to suit Volly 850.
x 8263
She's coming apart and it's looking good...
Here's the diff housing:
A collection of internals...
And the converter housing showing the oil filter...
Note the hedgehog-like swarf collection magnets on the oil filter! Nothing to get too anxious about. Quite normal actually...
Basically, everything looks good so far, all clutches look OK, all bearings look OK and there's very little debris in it. A bit of friction material but no powdered alloy as I've seen in worse ones...
I've not looked at the oil pump yet but I don't expect to see Armageddon in there either...
My original diagnosis of a breaking up lock-up clutch in the torque converter still holds and that is given some additional credence by it being rusty - indicating it's been jolly hot recently...
EDIT: the valve block looks fine too...
If all goes well tomorrow I'll have the oil pump in bits...
Deanxm
x 87
Its this place they look prety good and have parts diagrams of practicaly every box in existance.
Looking good Jim, i bet Chris cant wait for you to get it done :-D
D
XM Prestige PRV6 92
x 8263
Thanks Dean,
I'll be on the blower to them in the morning :)
Carsten S
Unread post by Carsten S »
CitroJim wrote: My original diagnosis of a breaking up lock-up clutch in the torque converter still holds and that is given some additional credence by it being rusty - indicating it's been jolly hot recently...
Nice work, Jim! :)
What is inside that converter? It is afaik impossible to open up for inspection, or?
Even if the lock-up clutch breaks, why don't the converter continues as "normal" converters?
x 8263
The torque converter is a sealed unit Carsten and can't be opened except with a hacksaw :lol: :lol:
Basically, treat it as a sealed unit and have it refurbished by a specialist...
I've seen some pictures of what they look like inside but if you picturte the lock-up clutch as being very similar in looks to a normal manual gearbox clutch ythen you'll not be far out...
Chris570
x 36
can i have it back now please
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
