CX Coil Woes
steveholl
CX Coil Woes
Unread post by steveholl »
Hi Folks
just joined, hope I'm in the right place to post this. My cx is causing me much grief of late. The latest is that the ballast resistor has snapped, it starts if I bypass the resistor. I have a new ballast resistor coil to go on, but no resistor. My question is, can I get a new resistor, or can I use a non ballast resistor coil? Its series 1 cx reflex that I foolishly use as a daily.....
any help would be gratefully received
many thanks
Steve
x 8407
Re: CX Coil Woes
Steve,
Welcome :-D
I'd reckon a standard 12V automotive ballast resistor should be OK. Don't run without else you'll burn out the coil... This one here on the 'bay might do maybe?
If not, a big heavy-duty wirewound resistor intended for electronics use should be a good substitute if you can't get the genuine article. We just need to know the value of the proper resistor... We just need a CX owner to get his ohmmeter out and read one...
robert_e_smart
x 14
Re: CX Coil Woes
Unread post by robert_e_smart »
Tell me more, I have an Athena with the same engine as Steve's Reflex.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 8407
Re: CX Coil Woes
Then you're just the chap then Robert!!!
To read it, disconnect the battery and the wire on the + side of the coil, switch your ohmmeter to the lowest ohms setting, switch on the ignition and read the resistance between the battery positive lead and the coil + lead. The reading will be the value of the ballast resistor...
robert_e_smart
x 14
Re: CX Coil Woes
Right, I'll give that a go tomorrow if I remember.
1991 BX 16 TGS Auto
steveholl
Re: CX Coil Woes
Thanks Guys
I appreciate the advice
steve
steveholl
Re: CX Coil Woes
Forgot to say, im sure my new coil had the ohm rating on it, might save robert a job
steveholl
Re: CX Coil Woes
HI Folks
just checked my new coil, its rated 0.9 ohm for the resistor......
thanks
Steve
robert_e_smart
x 14
Re: CX Coil Woes
I forgot to check mine, do you still need me to?
1991 BX 16 TGS Auto
steveholl
Re: CX Coil Woes
Hi Robert
Thanks for the offer, I think I just need to find a suitable replacement ballast resistor now. I've got the battery on charge as it went flat having the coil straight to the battery, I forgot to take off one night.......doh!
all best
Steve
x 8407
Re: CX Coil Woes
Steve,
Here's a big, hairy 1 ohm resistor that will do the job a treat...
0.9 ohms is a non-preferred value but 1 ohm should be fine and 50W power rating should be good too. It has it's own heatsink so bolt it to a piece of alloy sheet attached to something and you'll be well away...
x 5672
Re: CX Coil Woes
I forget exactly what we were up to at the time but one of the engineers I worked with chained around 20 of those and applied some juice to the mess. Mains, IIRC.
They exploded like hand grenades, it was pure luck that no-one was injured.
This was of course not using them in their intended application.
x 8407
Re: CX Coil Woes
That's engineers for you Steve...
Great fun :-D If we can make something go bang or explode we will...
As a kid I found that big electrolytic capacitors thrown onto a bonfire were quite satisfactory in the ornamental explosion department...
Mind you, they went off a lot better if you connected them across the mains....
steveholl
Re: CX Coil Woes
Thanks for all help.........I'll crack on with this and let you know how I get on
cheers
Steve
steveholl
Re: CX Coil Woes
Hi folks,
Well.....it is now running sweetly.. I got a big 150watt 1 ohm resistor from rs components, and put a new coil in as well. The old one was probably as old as the car...after initially wiring up the wrong way it started and rose majestically! Oh the joy... Now need to sort out soggy carpets. Thanks for all help and advice
Cheers
Steve
