Fitting manual Boost Controller Xantia TCT?
robert_e_smart
x 14
Re: Fitting manual Boost Controller Xantia TCT?
Unread post by robert_e_smart »
David, between us we can give loads of advice following many experiences of this job
Yeah, Buy a XM!!! :-D
Heater Matrices rarely fail on XMs, and can be changed in a couple of hours!
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
x 5672
Citroenmad wrote: Give me a shout if anyone very has trouble sourcing Forte Stop Leak on the old bay, I know of a good Forte stockist!
:-D :-D :-D
Diabolical
Unread post by Diabolical »
CitroJim wrote:
Chris570 wrote: I would offer to help you with it but i've just been called away to work in Cambodia for the next 6 months.
Come on Chris, you're restoring an XM - that job makes a Xantia heater matrix look like a Sunday afternoon snooze :lol:
If it wasn't for that bloody elbow then it would not be a bad job at all. David, between us we can give loads of advice following many experiences of this job :roll:
Toooo late I've done the K-Seal :oops:
Works or not I'm going to use car through Winter, It's my work car.
But I've decided on a plan :x use my Citroen CX TRi Safari for work in summer (putting the turbo engine upgrade on hold) and do a restoration on Xantia as it's got to the age/mileage for faults becoming the norm. No way am I going to unload a quality rarish Xantia, that's been my faithful workhorse for 7 years.
Thanks for all advice, I should have logged on this morning :( .
David
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
x 8397
I'm delighted you're going to do a restoration on the car over the summer David. Indeed, they're rare now...
The best tip I can offer for the elbow is to do as Chris and I did to separate his. Work at it from both ends using two people. split the old matrix at the inner flange joint and with one holding the elbow in the engine bay the other one can really give the stub pipes a good tug from within the car with plenty of room to work...
Room on the Turbo CT is actually the biggest problem.
