Fitting manual Boost Controller Xantia TCT?
Diabolical
Unread post by Diabolical »
A friend has given me a Manual Boost Controller that was used with his Cossie in MK 2 Escort.
He reckons it's a waste of time as after 3500 rev it cause's power to drop, he tried it on his works Dyno.
Any how a few mentions about these on Activas this Forum I thought no harm giving it a go :)
Any one out there post a pic or give me some advice on fitting.
David
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
x 8395
Re: Fitting manual Boost Controller Xantia TCT?
Chris570 is your man for this David, if he does not spot this and respond, give him a PM..
I've driven Activas with a manual boost controller and by gosh yes, it makes a difference....
A good difference :-D :-D :-D
Deanxm
x 87
Unread post by Deanxm »
Just pipe it up the same as the ecu boost controller, and make sure you leave it wired up and stick it behind the o/s strut top out of the way.
Is your controller a bleed type or seated ball type?
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Deanxm
x 87
CitroJim wrote:Chris570 is your man for this David, if he does not spot this and respond, give him a PM..
When are your doing yours then Jim :lol:
D
XM Prestige PRV6 92
Diabolical
Deanxm wrote:Just pipe it up the same as the ecu boost controller, and make sure you leave it wired up and stick it behind the o/s strut top out of the way.
D
By pipe it up the same as ECU boost controller I guessing you mean small bore pipe that goes into top of dump valve??
Just looked it up and I think it's Seated ball type, I will also need a Gauge for the pressure as well I think.
David
citroencx.co.uk
Deanxm
x 87
The ecu boost controller is on the drivers side mounted next to the strut top, it has a brown multiplug on it and 3 small bore rubber pipes disconnect the pipes but leave the controller plugged in.
One pipe goes to the waste gate actuator down the back of the engine, the other goes to the boost pipe just before the throttle at the front of the engine the 3 rd one is just an exhaust that runs back into the intake, remove this pipe and blank off the small fitting on the intake.
Now connect the new valve inline with the first two pipes.
You do idealy need a boost guage to set it all up properly and make sure you are not getting any boost spikes etc etc but you can use a compressor set the valve to 10psi prior to fitting it to the car for a rough setting if you dont have one handy at the time, if you overboost you will just get an eml and the fuel gets cut so you wont do any damage in the short term.
XM Prestige PRV6 92
Diabolical
Thanks Dean all makes sense now I have looked under the bonnet :( and discovered I now have a leaking Heater Matrix :cry:
I shall fit Boost Controller over the Weekend and I know I shouldn't BUT I will add some K-Seal :evil:
Thankfully I never got round to flushing Rad and block.
citroencx.co.uk
Deanxm
x 87
please no K-seal, its not a powertrain Engine :) , get some of that other stuff, that i cant remember now........................you know, the stuff your cant buy unless your in the trade...........
D
XM Prestige PRV6 92
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Deanxm wrote:please no K-seal, its not a powertrain Engine :) , get some of that other stuff, that i cant remember now........................you know, the stuff your cant buy unless your in the trade...........
Forte Stop Leak.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8395
Deanxm wrote:you know, the stuff your cant buy unless your in the trade...........
D
Forte Stop Leak. Often to be found lurking on eBay...
Please don't use K-Seal as I have a suspicion it causes the heater matrix connector to be come almost impossible to separate. Same may well apply to any other sealer except Forte.
I've used Forte in the past to stave off the dreaded day of a matrix change and the joint came apart fairly readily in that case...
x 8395
Sorry Richard, you beat me to it!!!
Deanxm
x 87
Thats the stuff.
A heater matrix isnt so bad, all you have to do is get the interior out, and the scuttle off and get to the elbow and not break it, i dont know what all the fuss is about :lol: .
D
XM Prestige PRV6 92
Chris570
x 36
Unread post by Chris570 »
for what its worth i'll wade in as well DON'T use K seal, its a total PITA to get back out again. Use either Forte Stop Leak (ebay) OR change the matrix, if you're lucky you'll be able to pop the heater matrix elbow off easily (i've found it easier with a roasting engine, move stuff out of your way first and you'll have much better access and you can give it a straighter pull) use a Valeo matrix as well, the pattern ones do fit but it becomes more effort. The matrix isnt a hard job to do really, just long, nothing to complex to it. I would offer to help you with it but i've just been called away to work in Cambodia for the next 6 months.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 8395
Chris570 wrote: I would offer to help you with it but i've just been called away to work in Cambodia for the next 6 months.
Come on Chris, you're restoring an XM - that job makes a Xantia heater matrix look like a Sunday afternoon snooze :lol:
If it wasn't for that bloody elbow then it would not be a bad job at all. David, between us we can give loads of advice following many experiences of this job :roll:
Citroenmad
x 110
Unread post by Citroenmad »
The manual boost controller really does make a very nice difference to the TCT, its how it should have been originally in my opinion.
Give me a shout if anyone very has trouble sourcing Forte Stop Leak on the old bay, I know of a good Forte stockist!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
