lhm tank level indicator
les
Locked user account
Unread post by les »
hi all top hat seems to be stuck at top of sight glass is there a fix for this or replacement required les
Xaccers
x 188
Unread post by Xaccers »
First are you testing with the suspension on high?
Second if you slap the top of the viewing dome does the fload bob down and back up? If so then you've put in more LHM than you need, which isn't a problem.
DIY sphere tool
les
Locked user account
stuck at top of sight glass regardless of fluid level tapping top dose nothing
Dommo
x 20
Unread post by Dommo »
les wrote:stuck at top of sight glass regardless of fluid level tapping top dose nothing
Is this with the suspension fully up in service high? If the suspension is in the normal running position then the tell-tale will be stuck at the top
x 94
Unread post by citronut »
this is a constantly reocuring misconseption, which i think should be a sticky, excuse the punn
i have never seen/had one stuck and it is usualy down to an overfilled tank,
the only prob with this is it can make a mess when the suspension settles all the way down, and the citro blood seeps out of the top of the tank,
raise the car fully up and syphon some of the citro blood out till the float drops between the two red bands,
if your still not covinced you can lift the dome/float out by pulling the two wires off, then rotate the base of the dome about a 1/4 of a turn now lift it out,
now you will be able to see how free the float will move up and down in the dome,
also once you see how it works you will see it is very unlikely to get stuck,
regards malcolm
x 8401
Malcolm, I concur with your thoughts :D
Usually, when at more or less right level I find the LHM to be about a finger's length below the filler when on normal height...
x 2938
I have to disagree with you boys on this, the indicator does on occasions stick at the top and no amount of tapping will get it to come down.
I've had a couple that did this even with the lhm drained, I fixed the last one by drilling a 1 mm hole through the plastic dome and poking it down with the drill bit then a dab of hard plastic adhesive over the hole.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
CitroJim wrote:Malcolm, I concur with your thoughts :D
It that a Jim or Malcolm fingers length? :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
you must use saw finger whoooops i mean swafegar after pocking you finger in the tank :shock: :lol: :wink:
regards malcolm
x 8401
Yep, never lick it, it tastes horrible...
mongoose100
Unread post by mongoose100 »
CitroJim wrote:Yep, never lick it, it tastes horrible...
Jim, now that you've stated that fact, I wonder if anyone will actually try it? Kinda as if to say; Yep, been there, done that. Never again :twisted:
Regan.
2001 Citroën C5 V6
1994 Citroën Xantia 1.9TD
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Come on its human nature, we are inqusitive creatures.If anyone says DONT we just have to.
You know "dont touch that electric fence around the horse field".And whatever you do dont try having a wee over it :shock: .
I think most of us have tried the various liquids in cars at some point, I hate rolling a ciggy when I am working on the car,that taste of burning oil does nothing for the enjoyment of a ciggy.
More to the point why would the indicator stick ?.
les
Locked user account
lhm indicator
regardless of height setting and fluid level{bled 2 litres} float dose not move at all
x 8401
mongoose100 wrote: Yep, been there, done that. Never again :twisted:
I have :twisted: I once thought it would be a good idea to syphon out an LHM reservoir to save removing it (this was in my early days of Xantia ownership) and I ended up with a mouthful....
LHM: good for the hair, not good to drink :roll:
Les, reckon a disassembly of the assembly is in order to see what's happened. It's an unusual one, that's for sure...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
A spoonful keeps you regular.
