Aargh! CRS strikes again...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Is it actually necessary to "index" the steering pinion valve?
I haven't good enough pictures of any bits, to see if it should matter or not. There were no match marks on it (I looked hard before reassembling the steering rack).
So - anyone care to comment?
Thanks, Adam.
x 8309
Basically, no...
Not that I can recall anyway...
Xac and I wondered this when we replaced his...
addo
x 95
Good; I was sort of thinking that.
Found an interesting comment on the "heavy steering when cold" phenomenon on a UK steering rebuilder's website. They reckon it's fine wear to the pinion valve's ring seal bores, and as hydraulic oil heats up the seal expands.
addo
x 95
Bunged it in without a worry and there feels a marginal bias - however I am running mismatched front rubber, so this comment needs to be taken lightly.
