Come again? :plexi wrote: Flippin heck mate. Your town is about to be turned into a tourist attraction.........................That's the Turin Shroud you got lookin atcha there!!![]()
Leaking Doseur valve?
Dommo
- x 20
Re: Leaking Doseur valve?
- x 8365
Some of us are seeing things in the outline of the LHM stain on your carpet Dom...Dommo wrote:Come again? :plexi wrote: Flippin heck mate. Your town is about to be turned into a tourist attraction.........................That's the Turin Shroud you got lookin atcha there!!![]()
Same sort of thing as people seeing the face of Elvis in a slice of toast and so on...
- x 94
Xaccers
- x 188
Here, I've cleaned the image up a bit
DIY sphere tool
DIY sphere tool
Chris570
- x 36
Chris570
- x 36
lexi
- x 134
- x 94
Dommo
- x 20
Changed the seal with the help of a friend yesterday, only took us about 3 or 4 hours
Removing all the intercooler piping and shifting the AC pipes out of the way takes a while!!
Is the seal meant to not look too bad? Certainly not with a big hole in it or anything? I didn't get chance to see if the leak has gone when I got to work this morning (the brakes do work though!)
I'll have a close look later, then set about getting the LHM out, although it might be easier to replace the carpet !
