Either that or he doesn't like hermyglaren wrote:So that's why my mate bought his wife a Micra when she passed her test
Why are 'luxurious' cars still rear drive?
DickieG
- Monaco's youngest playboy
- x 38
Deanxm
- x 87
addo
- Sara Watson's Stalker
- x 95
Micraps here, are sold on the following (advertised) points:
1. Room for your shopping
2. Good for compact U-turns (one presumes of dubious legality)
3. Built-in anniversary calendar (yes, really)
Most sold come with the 1.5 not the 1.2 engine.
The dearest one costs $20500 (£12780).
Back on topic, I've always considered hydraulic Citroëns a "leg" of the FWD tree, as their behaviour when braking in a corner is not the usual FWD characteristic.
While I'm at it, was Loeb's Xsara FWD or AWD?
Deanxm
- x 87
Ive found braking in a corner in almost any car only has one result, ditch contact
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
addo
- x 95
DickieG
- x 38
Are you sure? If so that's absurd, not only is the vehicle being destabilised by braking mid bend there is the issue of tyre grip trade off between braking and steering plus it encourages drivers to enter hazards at excessive speed, I really hope you've got that wrong.addo wrote:Come here and nearly run off the road laughing. If you don't brake in a corner here, you fail your driving test.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
HDI
- x 7
AWDaddo wrote: While I'm at it, was Loeb's Xsara FWD or AWD?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
addo
- x 95
OK, DG, I was exaggerating slightly.
But - there's no recognition of the idea that successful candidates may be driving other than a Getz or similar. You can brake noticeably mid-corner without failing, or ride the brakes down a long incline. Compression braking is generally frowned upon, too. The whole deal is awesome mediocrity.
- x 1922
What's that? Is it what I would term cadence braking?addo wrote:Compression braking
DickieG
- x 38
Its the same over here with the DSA (Driving Standards Agency), I have to really dumb down the training I usually do if I have someone about to undertake a DSA test. Over here in addition to the practical and theory test learners are given video scenarios where they have to click wherever they identify a hazard, however if you click as soon as the hazard appears you will fail the test as you need to wait until you are relatively close to the hazard, so rather than promote good observation skills it does the complete oppositeaddo wrote:The whole deal is awesome mediocrity.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DickieG
- x 38
You'll have to wait for Addo to confirm this but I think he means "engine compression braking".Paul-R wrote:What's that? Is it what I would term cadence braking?addo wrote:Compression braking
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
addo
- x 95
Yes, back when you used to double-shuffle to get second or third gear depending on the present speed and rate of slowing required.
The hazard perception touchscreen tests are here, too. If you are overly cautious, it pings you as well. Does my head in.
Once I had fully qualified, guess what I did on the way from the motor registry? Bought two longnecks.
After all, I could legally drink and drive now...
andy5
- x 103
There's a long downhill bit on the A8 motorway in Germany, where it descends from the Schwäbische Alb.DickieG wrote:You'll have to wait for Addo to confirm this but I think he means "engine compression braking".Paul-R wrote:What's that? Is it what I would term cadence braking?addo wrote:Compression braking
It's one of the old ones, 2 lanes, no hard shoulder, with quite a few bends, and in fact splits so the two carriageways go different ways around a hill.
In my car, it's easy enough to observe the 80 kph speed limit by changing down from 5th to 4th gear, with just a bit of 3rd on the slightly steeper bits, without using the brakes at all
But other people go down with a foot on the brake pedal almost all of the way, which must be heating the brakes up and adding to the chances they'll fade if really needed in an emergency.
HDI
- x 7
One of the reasons there are emergency sand traps at the bottom of severe gradients in the UK !!andy5 wrote: But other people go down with a foot on the brake pedal almost all of the way, which must be heating the brakes up and adding to the chances they'll fade if really needed in an emergency.
Have to admit to indulging in a bit of hooligan driving when I have a clear run down steep, twisty inclines ! Nothing like a bit of gravity to speed things up ! Although I over did it once, coming down the swiss alps in an 80's Alfa Guilietta with my father as passenger ! I placed too much faith in the Alfa's 4 wheel disc's and found myslef with a very long pedal approaching a RH hairpin at some speed ! Engine braking and a clumsy attempt at a Scandinavian flick JUST got me round ! We stopped a few miles later for coffee and a calm down, when we got out we saw the brakes were still smoking !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
isisalar
- x 3
Believe it or not, there is a Nissan micra SPORT out there!
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
