Another Xantia Heavy steering..
x 5656
That seems to give weight to my theory.
Did you remove the bolt at any point? If so the ball bearing that provides the seal may have gone AWOL - a regular occurrence.
If the bolt hasn't been fully removed then I would guess that there is some debris lodged in there preventing a seal. If it is hard enough it may have damaged the brass sealing surface.
I would carefully extract the bolt and have something to catch the LHM and the spring & ball.
Maybe a very quick spin of the engine on the starter to eject and muck trapped in there then the trick is to refit the ball and with a drift against it give it a whack to re-seat it - however, wait until Malcolm or Jim have the chance to see this before embarking on that possibly fatal rout.
Again it is something I have never been required to do so this is second-hand knowledge.
Ref
Unread post by Ref »
i removed it completely, so what you are saying that there's a ball and a spring that got lost and this's why the car won't rise?? ouch
Xaccers
x 188
Unread post by Xaccers »
Yup, about 4mm across, stainless steel so have a look under the car you might get lucky.
Otherwise heaf to the dealers
DIY sphere tool
Ref
i will have to do that in the morning hope it's still there, what if it's not there i don't think they stock a ball and a spring :roll:
Xaccers
x 188
They can order it in.
Do you have a scrapyard nearby?
DIY sphere tool
VertVega
x 13
Unread post by VertVega »
Ref wrote:... what if it's not there i don't think they stock a ball and a spring :roll:
I hope you'll find it but in case you don't you have to look for a 7 mm diameter bearing ball.
Edit: There is no spring behind it. Check PM for shop advice.
Form a scrap yard they'll most probably sell you the complete regulator set :(
No worries if you don't find, I can buy it here and post it to you :wink:
thorter
x 41
Unread post by thorter »
Try a bicycle shop if you don't find it. You may need to buy a pack with a couple of dozen. I doubt if it needs to be stainless. If the correct size is 7mm, then quarter inch might be worth a try.
Fred
VertVega
x 13
... and it looks like this.
Ref
No luck finding it and it's the week end all shops are closed, hopefully i can find it tomorrow, thanks alot guys :)
VertVega
x 13
Ref, if you don't find it, PM me tomorrow until 16:00, so that the postman can drop it in your mailbox on Tuesday :) .
Xantia must be up and running. You can offer me a virtual pint :wink:
Ref
VertVega wrote:Ref, if you don't find it, PM me tomorrow until 16:00, so that the postman can drop it in your mailbox on Tuesday :) .
Will do, will buy you a 6 pack no worries :wink:
Ref
Seriously the kind of help i get here is beyond words, VertaVega sent my the 7mm bearing ball with a diagram in a nice looking envelope :) now this's really something, i'm very grateful to all of you and to VV for the class A Offline help :)
on the other hand the car running great after new LHM and clean filters the ride is silky smooth :D and the steering seems to be alright no issues so far.
Thanks loads :juggle:
VertVega
x 13
... Image
red_dwarfers
x 58
Unread post by red_dwarfers »
Another success story, its what this place is all about :D
Kev
'19 C4 Cactus 130 Flair
