as the title says this's pretty much the problem, i checked the pipes looks like nothing's wrong with them, i'm gonna change the LHM and clean the filters, the car rises fine the STOP light goes off within seconds, I changed the accumulator Sphere couple of thousand KMs ago.
There's a buzz that comes from the Hydraulic pump when turning the steering wheel but only when i'm standing close to it.
What else should i look for?
Another Xantia Heavy steering..
Xaccers
- x 188
These threads may be of use:
http://www.frenchcarforum.co.uk/forum/v ... y+steering
http://www.frenchcarforum.co.uk/forum/v ... 77&start=0
DIY sphere tool
DIY sphere tool
Ref
- x 5688
You may need to remove the feed to the pump from the reservoir and prime that manually. A bit of a juggling act.Ref wrote:i just changed the lhm and followed all the instructions on jim's tutorial now the car won't rise, tried priming by untighting and retighting the 12mm screw and still nothing,what ami doing wrong?
Ref
Ok but how?myglaren wrote:You may need to remove the feed to the pump from the reservoir and prime that manually. A bit of a juggling act.Ref wrote:i just changed the lhm and followed all the instructions on jim's tutorial now the car won't rise, tried priming by untighting and retighting the 12mm screw and still nothing,what ami doing wrong?
- x 5688
Never having had to do it personally I wouldn't like to say more than I have but there is a description among Jim's treatment of the hydraulic system somewhere.
Essentially detach the feed to the pump from the reservoir and fill it with LHM then refit to the reservoir - sounds easy but I know from the descriptions given by others that it can be arduous.
Ref
- x 5688
- x 5688
That's OK, Jim uses it as hair conditionerRef wrote:it does and it splashed green stuff all over my face!
The only thing that occurs to me now is that the bleed valve is not seated properly and is preventing system pressure being attained.
Does the STOP light extinguish and do the brakes operate normally?
Ref
Ref
Xaccers
- x 188
You didn't remove the 12mm bleed bolt from the regulator did you?
DIY sphere tool
DIY sphere tool
