Another Lemming Jumps Off The cliff...
Chris570
- x 36
Dommo
- x 20
- x 8327
You need to be to be an Activa ownerDickieG wrote: Masochist
I've done a repair. I turned up a brass sleeve that would fit tightly into the spigot and the hole remaining in the rad. I opened the spigot and rad holes out to 5.5mm; there was about 2mm of hole depth in the rad before it opened out into the end tank. I bored the sleeve to 4.5mm so that water flow would not be adversely affected...
Once that was done, the sleeve was coated in Plastic Padding SuperSteel and gently pressed home. A coat of SuperSteel was applied around the spigot and the rad base to hopefully give a little more support.
Here's what the finished job looks like:
I just have to patiently wait a couple of hours now for the epoxy to set hard...
Fingers crossed...
Chris570
- x 36
all fitted don't worry.Dommo wrote:Well... 15... Lets not make it out to be worse than it is! Getting on with those parts Chris?Chris570 wrote:nothing is that hard on an activa, no job more than 20 mins
Martin is doing the last bits on the xant and then she's all done. I work quickly as Jim will attest to
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8327
Deanxm
- x 87
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8327
addo
- Sara Watson's Stalker
- x 95
- x 8327
addo
- x 95
Deanxm
- x 87
DickieG
- Monaco's youngest playboy
- x 38
I'd be pouring the petrol over the roof rather than in the tank, no further clues req for what I'd do next,,,,Deanxm wrote:at 13 1/2 i would be looking for a hole in the tank not a weak spark![]()
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8327
Looks like I may have saved my rad
Reassembled and ran her up to temperature until the fans cut in and so far, touch wood...
Adam, I'd say you had a very, very rich mixture there. Weak sparks might cause high HCs but for consumption like that you must be pouring it into the cylinders neat!!!
has it got a 'flapper' AFM on it? (i.e. Bosch LE Jetronic)
Basically, go to your local rego place and see what the emissions look like, that'll give a few good clues...
I assume they check emissions during the rego as they do here during MOT...
Yours should be no more than 3.5% CO at idle and considerably less as it revs a bit...
Get them to check HCs too as this'll prove your weak spark theory...
Oh, and check timing too.. If it's retarded it'll drink like a fish...
Has it got a vacuum advance capsule on the dizzy? Check it's not ruptured if it has and also check the pipe to it is good..
Then have a good butchers around for manifold air leaks...
addo
- x 95
No emissions checks here.
It's got the later style of computer - not like a 205 or early 405 - where it uses MAP in conjunction with IAT. Distributor is the simple type, no advance just a rotor and cap.
TBH I haven't even plugged in the Lexia yet - could try it tomorrow but I have issues at times with the 30-pin plug.
Waiting to get the Alfa back before demolishing another car in the name of repair.
- x 8327
addo wrote:before demolishing another car in the name of repair.
Read your plugs! Bet they're a bit swarthty if not downright black...
Sounds like a sensor is acting up, either MAP or the coolant temperature sensor..
Does it smell?
Rad seems to be holding after a quick spin...
