Another Lemming Jumps Off The cliff...
Chris570
x 36
Unread post by Chris570 »
nothing is that hard on an activa, no job more than 20 mins
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
Dommo
x 20
Unread post by Dommo »
Chris570 wrote:nothing is that hard on an activa, no job more than 20 mins
Well... 15... Lets not make it out to be worse than it is! Getting on with those parts Chris?
x 8444
DickieG wrote: Masochist :lol:
You need to be to be an Activa owner :lol: :lol: :lol: :lol:
I've done a repair. I turned up a brass sleeve that would fit tightly into the spigot and the hole remaining in the rad. I opened the spigot and rad holes out to 5.5mm; there was about 2mm of hole depth in the rad before it opened out into the end tank. I bored the sleeve to 4.5mm so that water flow would not be adversely affected...
Once that was done, the sleeve was coated in Plastic Padding SuperSteel and gently pressed home. A coat of SuperSteel was applied around the spigot and the rad base to hopefully give a little more support.
Here's what the finished job looks like:
I just have to patiently wait a couple of hours now for the epoxy to set hard...
Fingers crossed...
Chris570
x 36
all fitted don't worry.
Martin is doing the last bits on the xant and then she's all done. I work quickly as Jim will attest to
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8444
That's swearing time, not actual working time...
:roll:
Deanxm
x 87
Unread post by Deanxm »
:lol: There was a jeff site more than 15 minutes swearing while i done my heater matrix i can tell you!
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 8444
And a lot more doing a manifold gasket too :twisted:
If I contributed to a swear box I'd be bankrupt by now... It would cost a lot more than the petrol to run the blessed thing :twisted:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
My 605 is sitting around 21 litres per hundred km around town. Wanna swap? :lol:
x 8444
addo wrote:My 605 is sitting around 21 litres per hundred km around town. Wanna swap? :lol:
Gosh, that has a bit of a drink problem Adam.. What's that in MPG?
makes an Activa look positively frugal...
addo
x 95
13½
:cry:
Weak spark, I think. Compression is good.
Deanxm
x 87
at 13 1/2 i would be looking for a hole in the tank not a weak spark :shock:
D
XM Prestige PRV6 92
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Deanxm wrote:at 13 1/2 i would be looking for a hole in the tank not a weak spark :shock:
I'd be pouring the petrol over the roof rather than in the tank, no further clues req for what I'd do next,,,,
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8444
Looks like I may have saved my rad :D Reassembled and ran her up to temperature until the fans cut in and so far, touch wood...
Adam, I'd say you had a very, very rich mixture there. Weak sparks might cause high HCs but for consumption like that you must be pouring it into the cylinders neat!!!
has it got a 'flapper' AFM on it? (i.e. Bosch LE Jetronic)
Basically, go to your local rego place and see what the emissions look like, that'll give a few good clues...
I assume they check emissions during the rego as they do here during MOT...
Yours should be no more than 3.5% CO at idle and considerably less as it revs a bit...
Get them to check HCs too as this'll prove your weak spark theory...
Oh, and check timing too.. If it's retarded it'll drink like a fish...
Has it got a vacuum advance capsule on the dizzy? Check it's not ruptured if it has and also check the pipe to it is good..
Then have a good butchers around for manifold air leaks...
addo
x 95
No emissions checks here. :twisted: It's got the later style of computer - not like a 205 or early 405 - where it uses MAP in conjunction with IAT. Distributor is the simple type, no advance just a rotor and cap.
TBH I haven't even plugged in the Lexia yet - could try it tomorrow but I have issues at times with the 30-pin plug.
Waiting to get the Alfa back before demolishing another car in the name of repair. :lol:
x 8444
addo wrote:before demolishing another car in the name of repair. :lol:
:lol:
Read your plugs! Bet they're a bit swarthty if not downright black...
Sounds like a sensor is acting up, either MAP or the coolant temperature sensor..
Does it smell?
Rad seems to be holding after a quick spin...
