One of the brake lines that run the length of the car from the front to the rear is badly corroded near to where it joins the fexi hose at the rear.
It looks like a 3/16 pipe, am I right? What are the union sizes? Can i use a standard flaring tool?
Citroen want £66 for both pipes which is a joke. I was hoping just to make one up.
I cannot see most of the pipe as is it covered by shielding, is there a join under the car or does the pipe run right into the engine bay?
Thank you.
C5 Estate brake line replacement - What do I need?
Buchan Loon
I've got a similar problem with my car. Pipes are 3.5mm or 4.5mm and specific to Citroen. Bench flaring tools are available but around £200. If you want to flare on the car there are mini tools, but they are very difficult to come by, one on Ebay this week made nearly £90!
Your best bet is to measure the length of pipe you need and get a company called Pleiades (google them) to make up a pipe complete with ends for you mail order
*sorry, just noticed yours is a C5, mine is a Xantia, I'm sure someone will be along to correct the above if it doesn't apply to C5's*
1999 Xantia 2.1 TD SX
- x 94
- x 5645
PeteB
- x 94
PeteB
BX
- x 19
PeteB
