Xantia wiper problems... "Solved"
fridgedoc
Unread post by fridgedoc »
Hi Guys
Sorry have not posted pic's yet been raining and hospital visits, having a small problem with the wipers no intermittent wipe and no wipe when washers used I'm guessing it's a stork problem, any pointers please
Many thanks
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
Chris570
x 36
Unread post by Chris570 »
i would think relay at first. as for both not to work there must be 2 switches dead in the stalk as opposed to one dead relay. someone will be along in a bit to say where the relay is, might be worht saying what model of xantia you have
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
fridgedoc
Hi chris thanks for your post the model is under my signature, just like yours :)
Bonne Chance
Stephen
Chris570
x 36
i knew that 8-)
well i guess that answers the question of year as well :)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
VertVega
x 13
Re: Xantia wiper problems
Unread post by VertVega »
fridgedoc wrote:... no wipe when washers used ...
I had this problem and it was solved by wiper stalk replacement 8-)
Here's my thread, if any help --> Xantia II Windscreen washer problem ** Solved **
It still works fine.
fridgedoc
Hi VertVega & thanks for your post
I'm not too sure it's the same problem I have no intermitant wipe and no wipe when washers used single wipe works and normal/fast wipe works will have a look at relay first then stalk
Bonne Chance
Stephen
Old-Guy
x 24
Unread post by Old-Guy »
I have exactly the same problem, and it's not the stalk (tried that).
The same timer/relay does both intermittent and wash/wipe. For 1995 model year onwards, this is relay 12 which is the top one of the two located to the left of the fuses (on a RHD car these are hidden behind a trim panel. This relay has 6 pins - I think it's the only one with that many. I haven't had time yet to find a replacement, so I can't be sure that it's the relay, but the evidence is pretty compelling.
fridgedoc
Hi Old-Guy & thanks for your post
sounds feasable to me but I have a LHD so any idea where this relay would be? somewhere near the steering column? will try and find it on my dead Xantia as it was all working OK on it, will let you know how I get on
Bonne Chance
Stephen
Old-Guy
x 24
Assuming that Citroen only used completely different components for the RHD minority when absolutely necessary, I'd guess that they used the same fuse-bax/relay board for both LHD and RHD though perhaps in a different location. Providing you know where the under-dash fuse board is, I'd expect to find the relay in the same place (top relay to the left of the spare fuses, behind the trim panel. Logically it would be in the mirror-image location, above the driver's left shin. But maybe that's too simple?
fridgedoc
Hi Old-Guy & all
Firstly as promised pictures of my Xantia's, the old (blue) and the new , well new to me...don't you just love photobucket !!!!!
The new again
What fun!!!! and you get to see a little bit of France
Now to the serious stuff................
Wiper relays or not!!
This is under the steering wheel once the plastic covers are removed
the relay top left is the indicator relay there is one underneath left and the two on the right, orange and light grey with what looks like vent holes, I cannot get these buggers out I am afraid I will do some damage is there a special way of getting them out? Is there anyone with a LHD who knows which is which?
As you can see this problem is now solved.
To the right of the green relay bottom left is the screw you can see the silver tag (just) this is the blue (intermitent wipe) relay
Bonne Chance
Stephen
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The vented one (as you call it) is a warning beeper for headlights on.
fridgedoc
Hi addo & thanks for your post
I think 'its if the light switch is on not just headlights, thank you for pointing it out but
Which one if any of these is the intermitent wipe one?
Bonne Chance
Stephen
fridgedoc
Hi Guys
got my photos back ......thanks photobucket
Bonne Chance
Stephen
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
Im not 100% sure but i believe the relay you are looking for is right up underneath by the bottom green relay and is held in by a bracket that is bolted/screwed into place.
I had a problem with my mk1 which has now in typical Xantia fashion sorted itself but when fault finding on another mk1 with working wash/wipe and intermittent function removing all obvious relays it still worked and only by touch could i feel the relay clicking,not sure how to get at it though :oops:
Colin
fridgedoc
Hi Colin
How right you are, blue relay tucked right up under the metal frame that holds the green relay and all you can see (with a torch) is a screw head, once the screw in removed you need to curl your fingers and push up the relay so the fixation tab clears its slot then carefully tease the relay down so you can remove it from its socket, what a ridiculous place to site it.
Can this be made a sticky, to aid any other poor person with this fault
Bonne Chance
Stephen
