Hi when turning the heater on to demist there's a strange smell coming through the vents. Although carpets aren't wet the coolant level needs topping up occasionally so I suspect a leak of sorts.
To use K Seal can I just empty it into the header tank or is there a better way to ensure it circulates decently and hopefully seals the leak?
thanks for reading!
Xantia heater matrix leak suspected
ed4ferrets
Ed
'63 Renault Caravelle - stored
'99 Xantia 1.9TD Estate - matrix done:))
exect
citroenxm
- Fallen Hero
- x 70
If yur getting a curry type smell then the matrix is on its way...
I personally dont beleve in these sealing additives and think they can causr blockages in other places... Sounds like a dash out job is on the eay...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8327
I'm not wonderfully taken with them myself. K-Seal I have very little faith in but one I know works is Forte Stop Leak. It's harmless too, looking like milk and it's recommended by Valeo as well.citroenxm wrote: I personally dont beleve in these sealing additives and think they can causr blockages in other places... Sounds like a dash out job is on the eay...
Forte will stop a small leak for a while as I found on my old 2.1TD but eventually the matrix will need replacing which, as you say Paul, is a dash out job. Tedious but not hard.
Sealants generally, all except Forte, may block fine passageways and I'd NEVER use them on an automatic under any circumstances as I've seen coolers bunged up with the stuff...
Speaking of matrix replacements, I'm soon off to assist with just that job in a few moments....
citroenxm
- Fallen Hero
- x 70
- x 8327
I wishcitroenxm wrote:Hey jim...
Shouldnt the xm come first on yur list??![]()
paul
It sits there begging me to get stuck in but time and other needs always gets in the way
No worries, I have a week off next week; guess what I'll be doing when not going to Aber to take Robyn to Uni?
Yep, that's it, wall-to-wall XM spannering
citroenxm
- Fallen Hero
- x 70
- x 8327
addo
- Sara Watson's Stalker
- x 95
- x 8327
No, but be sure they'll be into XMs in a big way...addo wrote:Are we taking bets on the (-censored-) of any future sprogs, yet?
This, and it's not to upset you Ed, but this is what the interior of a Xantia looks like during a matrix swap...
On this one, Chris570's Activa, the elbow was a sod and a half. It would just not come apart.
We hit on a plan the involved splitting the joint at the matrix end, splitting the heater box, undoing the matrix pipe plate screws and then having two people work the elbow, one from the engine bay and the other inside the car tugging on the other end..
It worked a treat but it still took us about an hour and a half to separate the joint
That and the rain made it a bit of a log job. Finish off tomorrow...
addo
- x 95
- x 8327
Just an old can of Coke Adam!!addo wrote:Nice bit of pr0n there. Do I see vestiges of a little liquid therapy in the door pocket?
The seat heater control connectors, the ones that go to the temperature selectors. This Activa has the rare winter pack fitted...addo wrote:What are the yellow topped wiring bits next to its Autoliv module?
XantiaDaveEire
- x 4
