Evening guys,
after the demise of my remote locking due to a confused wifey as to why it wouldnt work so press harder and pop the micro switch off, and my unsuccesful attempts at soldering, ive decided to seek a couple of spare units to get reprogrammed via my garage mans as he has lexia,
Now, the numpty questions! Do the keys that are being programmed need to have a cut blade to work the ignition or do they simply need to just be in??
Also! Would it be possible to just switch the boards from inside the other keys to the cut key pod and program them so to have programmed pods and get some blanks cut at a later date for the spare pods?? Like one of these?? http://www.ebay.co.uk/itm/CITROEN-SYNER ... 4aad89ff97
Ordo i need that done before,??
sorry for the questions but like to get it clear in the head before i speak to my mechanic man!
Ta muchly in advance!
numpty lexia key programming question!
Timmo
- x 168
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
DickieG
- Monaco's youngest playboy
- x 38
Re: numpty lexia key programming question!
When programming the key transponder Lexia states "use key no ** and turn on the ignition" (or words to that effect) so in answer to your question I'd say you need a key cut so that the ignition can be turned on by it.Timmo wrote:Do the keys that are being programmed need to have a cut blade to work the ignition or do they simply need to just be in??
The remote locking function is separate from the key programming, so if you programme a remote then remove the PCB and put it in another case it should still work.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Timmo
- x 168
Okay thanks for that, so be getting a couple of blanks cut prior too,
Will pop down tye french breakers down the road and see if they have any keys laying in a box!
and will try the yard in the village too as there always great!!
'58 C2 Code
'58 C2 Code
- x 1933
On the C5, when I had a blade cut I needed a new transponder chip to go inside the plastic handle. These chips are single time programmable only and will need replacing to pair up with your car's ECU.
I'm not sure if your car also uses single programmable chips but it's something to bear in mind.
They're about £15 or so from locksmiths. Not all locksmiths can offer the full key replacement service so you may have to look around.
DickieG
- x 38
I've re-programmed several S2 Xantia remotes and keys without a problem.Paul-R wrote:On the C5, when I had a blade cut I needed a new transponder chip to go inside the plastic handle. These chips are single time programmable only and will need replacing to pair up with your car's ECU.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Timmo
- x 168
Thanks guys,
i plan to get a couple f key blades cut for a pair of remote locking keys and also a plain key just for locking the doors (ajd other keys in safely hidden) when off for a surf! - no need to worry if it gets wet then!!
'58 C2 Code
'58 C2 Code
The Birdman
Check prices for codes , i can get both transponder and mechanical key codes for your car for £5 .
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
- x 94
why cant you just switch boards from S/H fob/s to your original fob with corect key blade, just for the purpose of re/programming the remote's,
also i dont mean to be a party poooper Mr Birdman,
but as i have said in another thread citroen and peugeot give the radio and securaty card key codes out for nout now, at least in the UK, as i have had both from my local dealers now,
regards malcolm
regards malcolm
Timmo
- x 168
The Birdman
I know mate but in my part of UK they are £18 from the Dealercitronut wrote:why cant you just switch boards from S/H fob/s to your original fob with corect key blade, just for the purpose of re/programming the remote's,
but as i have said in another thread Citroën and peugeot give the radio and securaty card key codes out for nout now, at least in the UK, as i have had both from my local dealers now,
regards malcolm
