remote key will unlock but not lock, battery??
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Evening all,
remote key stopped locking the car this avo, lock with the key as normal and will unlck with remote fine, just not lock,
would this be likely to be bateries??
Ta muchly in advance.
'58 C2 Code
'58 partner teepee outdoor
x 1955
It might be. It's more likely to be the contacts inside the remote.
I can dismantle the Xsara and C5 remote, as if I'm replacing the battery, and clean the circuit board. I don't know whether that's possible with yours though.
Be careful cleaning the springy rubber bit though as it's possible to "clean" the conductive layer off by mistake - just dab it with a cloth.
Timmo
(Donor 2022)
x 168
Thank yoe! Will have a look later and see,
'58 C2 Code
Timmo
(Donor 2022)
x 168
Appears that the button was pushed a bit hard as had broken the solder connections, so time to dig out the fine tips tomorrow and fix it!!
Thanks for the tips!
'58 C2 Code
