C5 HPi Big Lever
birstall
C5 HPi Big Lever
Unread post by birstall »
So what's the big metal lever for in the engine compartment that swings horizontally back and forth? (Somewhere in the area below the HP pump). Summer/Winter setting adjustment?
Current: C5 HDI Exclusive Saloon
Past : C5 HPI Exclusive Saloon
C5 HPI Exclusive Est
Xantia 1.9TD VSX
BX 1.7 TZD
x 5652
Don't touch that - it's the self destruct activator!
Citroenmad
x 110
Unread post by Citroenmad »
myglaren wrote:Don't touch that - it's the self destruct activator!
Only fitted to the HPI petrols :roll:
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1056
Re: C5 HPi Big Lever
Unread post by wheeler »
birstall wrote:So what's the big metal lever for in the engine compartment that swings horizontally back and forth? (Somewhere in the area below the HP pump). Summer/Winter setting adjustment?
Do you have a picture ?
birstall
I've got a picture but I can't seem to post it up anywhere.
Can I email it to someone to give me a hand?
Cheers
Pete
Xantia 1.9TD VSX
BX 1.7 TZD
x 5652
email it to me.
x 5652
That's perhaps a little difficult to make out, larger image if you click on this:
I am clueless, not many members have HPis so it could be a while before this is resolved.
Citroenmad
x 110
Where is that?
Looks like its ontop of the gearbox?
03 Seat Arosa 1.0S
Toby_HDi
x 3
Unread post by Toby_HDi »
Of course! I was thrown by the HP pump reference but later pumps were on the gearbox end driven directly off the camshaft.
Looks like gear linkage to me.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Citroenmad
x 110
A Seat TDi I used to have had a big metal weight like thing on the gear linkages, I think it was some sort of centralising weight.
03 Seat Arosa 1.0S
birstall
OK, I'm going to throw it into the back position before I set off in the morning and see what happens.
Xantia 1.9TD VSX
BX 1.7 TZD
x 2941
Those are the gear control levers, connected to the gearshift by the cables, one is the move across neutral and the other shifts the gears in and out.
x 1056
Yep deffo the gear linkage, if you get someone to move it while you are inside you will see the gearstick moving.
birstall
Yes, that's what it is - mystery solved.
Thanks for all your help.
Pete
Xantia 1.9TD VSX
BX 1.7 TZD
