Peugeot 407 Sat Nav Problem :(
LlanelliP
Unread post by LlanelliP »
The Sat Nav in my 407 is not detecting my current location, it shows me as somewhere in Coventry?!?
How should I start to solve this?
Any ideas/comment welcomed
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I don't know much about 407's but C5's apparently have a lot of of problems with the aerial and IIRC in particular the base with regards to water ingress. I don't know whether 407's have the same aerial/base but its got to be worth a quick look.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
What about driving to the exact location shown, then disconnecting the battery for 24 hours, to reset the satnav? :shock:
More seriously, as DG infers you need to get it plugged into a Peugeot Planet diagnostic station. Look up the "Lexia Locations" elsewhere in this Forum, as many of their owners also have the Peugeot software.
x 8213
Re: Peugeot 407 Sat Nav Problem :(
LlanelliP wrote:it shows me as somewhere in Coventry?!?
It's sent you to Coventry has it? So, it's not talking to you either then?
It is quite frequent that a satnav would stick on its last known location if it receives no signals so the aerial is a good spot to look..
LlanelliP
I have been told that the aerial is integrated into the rear window. Would this mean replacing the glass?
What do you guys think?
addo
x 95
I would believe there is a base unit signal amplifier, probably under the roof lining or a trim mould right next to where the screen wiring starts. That's the usual culprit.
x 1052
Unread post by wheeler »
LlanelliP wrote:I have been told that the aerial is integrated into the rear window. Would this mean replacing the glass?
I would imagine that the aerial for the radio is integrated into the rear glass but i doubt the GPS reciever is. Is there no sign of an aerial on the roof anywhere ?
