About once in every five times I go to start the 405 1.9TD up, when I turn the ignition to the start position, everything cuts out!
Lights, ignition icons, interior lights - Everything!
If I turn it back to off, then turn it to the starting position again, everything goes well, and it fires up.
And before you say it, I have cleaned the battery terminals, and the connectors on the leads.
Electrical issue...
CitroenLover
Electrical issue...
Citroen's may be slightly unreliable... But that's what makes them fun!
- x 5683
CitroenLover
addo
- Sara Watson's Stalker
- x 95
OnlineCitroJim
- x 8444
And never forget earths, especially the thick earth cable to the stud on the top of the gearbox and the other thick earth cable 'twixt battery and bodyshell.
Sometimes the crimps (where the cables enter the clamp) on the battery clamps can go high resistance. They often give themselves away by running warm when there is a heavy load on the go.
