C5 2.2 HDI lower ball joint woes
andybsmith
After having tried to remove the old lower ball joint I gave given up and ordered a replacement hub carrier from ebay. what I need to know is the torque settings for the front wheel bearing nut.
Its a French car, it has foibles, patience is a virtue
Xantia VSX 155 bhp
C5 2.2 Exclusive
Xantia VSX 155 bhp
C5 2.2 Exclusive
JohnD
- x 72
- x 8457
KennyW
- x 165
Andy,
I've never had a problem in undoing the front hub nut on any car i've owned. Just did my front outer CV joint today. 2 hours for complete job.
Impact socket, breaking bar and 6' scaffolding pole sucess
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 1955
Now that's just boasting. I can get the nut off with a 5' length of gas pipe.KennyW wrote: 6' scaffolding pole sucess
KennyW
- x 165
Paul,
Age caught up with me, I used to use a 3' foot pole
Kenny
Kenny
- x 8457
- x 1061
I think the problem though was getting the balljoint out of the hub not undoing the nub nut.KennyW wrote:Andy,
Impact socket, breaking bar and 6' scaffolding pole sucess.
Kenny
KennyW
- x 165
I have remove 3 lower ball joints in the past by removing hub then applying heat to casing and using removal socket with either impact wrench or breaker bar with 6' pole attached
HUb is secured in a bench vice.
Kenny
Kenny
