cam shaft.........shafted
fridgedoc
Unread post by fridgedoc »
Hi guys cam shalt is buggered.
good news have found a 1991 xantia with lhm pump gone, so he says!!!
will the pump of mine fit? both cars are diesel
Many thanks
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
1991 Xantia???? they didn't sell them then...in the UK at least
Are you wanting to put Your 199(1!) LHM Pump on his 1994 car...
Is a possible NO.. As 1992 Xantias used a different Pump to later cars...
It was around 1993 they changed from a Suspension Sinker System like the BX, to an Anti Sink System, with PAS driven directly from the Pump, and NOT the flow divider...
If you have NOT broken your cam, you could get away with putting another Cam shaft in your Xantia...
Paul
A very sad...
1994 XM 2.1 d auto
fridgedoc
Hi Paul
the cam is not snapped/broken, engine had run low on oil and the cam has siezed and is now grooved and one of the cam bearings has cracked so I am guessing the pistons/valves are damaged,is it worth repairing???
this other vehicle has leather interior not seen that before but I'm no expert and they said it was a 1991, maybe a special? it is France you know :) and the hydraulic pump is not working, it's about one and half hours from me, I'll post a picture in a minute
Bonne Chance
Stephen
fridgedoc
Hope these work
Nice interior
hope it's just got a leak and the pump is OK
Bonne Chance
Stephen
citroenxm
Fallen Hero
x 70
You will need to check the Pumps (I assume you mean suspension pumps) between the two cars... The 199(1?) car will have ONLY two pipes going to it, One Metal, one Rubber... and yurs being later should have Three... One Rubber, and Two meatal ones each side of the rubber pipe..
If this is cae case then they will NOT swap over, and you CANNOT simply block the second outlet....
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
One big problem with the 1991 one.
Steering wheel is on the wrong side...
Still, if nothing else, if the one with the broken engine is in better nick it can donate an engine to the cause...
Manual leather seats too, never seen those before 8-) I always thought they were stuff of legend...
citroenxm
Fallen Hero
x 70
Jim, his 1994 one is LHD too..
Hasn't AndMcit got Manual Black leather for sale, or did have??
Paul
A very sad...
1994 XM 2.1 d auto
fridgedoc
Hi Paul
Thanks for your input are either of these 2 vehicles close to me here in
>France?
Bonne Chance
Stephen
