synergie alternator
dave2011
synergie alternator
Unread post by dave2011 »
hi all.ive got a p reg synergie and the alternator light has decided to come on but goes out when i press the acellerator and ive found a hdi synergie in the breakers yard. would this have the same type of alternator on it? cheers guys :)
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
More than likely different as many HDi's have glow plugs to heat the coolant so have alternators with a much higher output but as long as the external dimensions are the same I can't see why it can't be used. Alternatively why not look for an alternator from a Xantia, Pug 406 with the same engine?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
dave2011
cheers dickie. should be able to find a 406 in the scrappy. what year do they go to and from with the xud engine in? cheers :wink:
x 1240
Unread post by Peter.N. »
From about '99 on but the 406 uses a diesel type auxilluary heater so don't know if the alternator is the same. If its the same size should be OK.
dave2011
Cheers guys. ;@) just got one from the breakers yard from a 406 n fitted now.
