old one seized as per normal but is it likely to have blown a fuse somewhere?
so in no order of preference...
is there a separate fuse for this somewhere?
is it worth replacing temp sender, if so, again where am i looking on engine for it?
i tried to get temp up way high but failed even with 25C ambient temp today or so display says.
turned on air-con as well, seem to remember something about these using the rad fan?
fan does work, Heath Robinson wiring to check before final mounting
no joy for switching on fan so let the frustration begin
