306 sump plug
froggy
(Donor 2026)
x 4
306 sump plug
Unread post by froggy »
Hi, Iam unable to undo my wifes sump plug on her 306 . the square inner fitting is rounded and two of the edges on the hexagonal are rounded too ! Is it a case of trying the " Bahco " pliers .
cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8444
Even if the outer hexagonal edges are a bit rounded, a good hexagon (as apposed to the more normal bi-hex) socket should still get sufficient purchase on it Terry...
Else Bahco but purchase will be a bit tricky on such a small 'nut' area...
Else that, get hold of a square that is a little bigger than the existing and drive it in. The watch-word here is "a little" and don't go too mad or the sump might crack.
Failing that, use a small cold chisel to raise an 'edge' on the hexagon and then using a good punch, drive the plug undone on the edge you've raised.
froggy
(Donor 2026)
x 4
306 sump plug
thanks Jim.
Terry
