c5 auto box
lexi
x 133
c5 auto box
Unread post by lexi »
What box does the early C5 2.0 Petrol auto have?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8391
The AL4 Lexi :(
From what I've heard, the only suitable emoticon for such is one of these: :evil:
I fear you may be a tad disappointed in it after enjoying the 4HP20 in the V6...
Citroenmad
x 110
Unread post by Citroenmad »
If its a 2.0 HPi petrol C5that is reason enough not to buy it ... if its the 2.0 16v then they are good lumps. The auto box im not sure on, I have been in a automatic 2.0HDi, which I assume had the same box and it was disappointing - noisy gearbox, not excellent changes and hanging on to the gears for longer than most autos. Shame as I wanted to like it as a C5 diesel auto would be a good match. Does anyone know if the 2.2HDi C5 uses a better gearbox?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The box isn't so bad as most make out. When running sweetly it's a great pair to the motor.
Hanging on to gears happens when cold, when sensors aren't all sorted, and when electrovalves aren't right. A harsh 3-2 downshift when lugging at 25MPH is the only fault I've had trouble beating.
sifaan
Unread post by sifaan »
Citroenmad wrote:Does anyone know if the 2.2HDi C5 uses a better gearbox?
i believe the autoboxes on all are AL4 4-speed, except the V6 which came with AM6 6-speed
Clogzz
x 40
Unread post by Clogzz »
The AL4 has a paddle stick, and sport and snow buttons.
The 2.2 HDi doesn’t have the AL4 because it’s meant for medium-torque engines.
Citroenmad
x 110
Are the earlier C5 autos supposed to have a noisy box? I looked at a 2.0HDi 110 auto recently, 50K miles and full Citroen history but the box was extremely loud and so didn't buy it. Disappointing really.
03 Seat Arosa 1.0S
x 8391
Loud in what way Chris?
Basically no, an autobox should be silent...
Citroenmad
x 110
It was whining loudly, the gearchanges were noticeable and the length of time it held onto gears made town driving a chore.
I hope that is not how they should be, as I did think it would be a good combination in the C5, a diesel auto, but it wasn't a nice box.
03 Seat Arosa 1.0S
x 8391
Whining is bad Chris. It may have been low on fluid. Or else the diff was on the way out... Very sensible to pass it by, especially with rough changes too.
Mine whines very quietly on the over-run under certain circumstances but at nearly 177,000 miles I forgive it :lol: :lol: :lol:
Citroenmad
x 110
Well that is reassuring and my search might continue for an auto again, as I had only been looking for manuals after experiencing that.
03 Seat Arosa 1.0S
Clogzz
x 40
When test-driving a C5 with an AL4 box, slow down to unlocked first gear as often as possible, then accelerate to check for throttle lag.
We’re plagued with them and there’s no solution in sight.
The fault is not hydraulic, it’s the ECU wondering if it should downshift to first gear.
Story here:
http://www.aussiefrogs.com/forum/showthread.php?t=88999
cachaciero
x 9
Unread post by cachaciero »
FYI The 2.2 has a 4HP20, the gear selector arrangment is identical as far as I can see on all autobox installations regardless of the box actually fitted, not surprising really as it's all electronic. Having sorted out issues of duff data getting sent to it from the ESP sytem I quite like the combination, my only bitch is it's propensity to change down far to early when descending slopes, but it's easy to overide it and often find myself driving it manually though in all honesty it's hard to improve on what the box does automagically.
The later MkII 2.0 ltr and I believe the 2.2 (172) has a six speed Aisin box.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
lexi
x 133
A Toyota box on a Cit. :shock:
I had a ZX 1.9 Auto diesel. It was not bad really. I thought it would be p**s poor compared to the Honda boxes we had but it was fine.
Not an inspired drive mind you. Mmm. AL4= dexron..........I have loads of this :lol:
Just browsing the market ATM.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8391
lexi wrote:Mmm. AL4= dexron...........
It has expensive tastes Lexi, they don't like Dexron :lol: Actually AL4=LT71141 (same as the 4HP20)...
