Hi, When I start my ,1997 Xantia , the suspension rises, stops at its height. Then as Iam about to drive off, it jumps up again ( back only )
is this correct ? many thanks in advance, cheers Terry .
Xantia suspension
froggy
- (Donor 2026)
- x 4
Xantia suspension
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 94
OnlineCitroJim
- x 8457
The jump you see Terry is the rear anti-sink valve closing when it shouldn't. This may be caused by you keeping the brake pedal pressed or by a completely flat anti-sink sphere. Despite it's name, the anti-sink sphere, whilst having nothing to do with sinking does have a little to do with preventing 'jolts' in the rear suspension by maintaining a reserve of pressure to keep the anti-sink valve from inadvertently operating as it appears to be doing.
It will often happen if you keep your foot on the brake so it's worth consciously trying not to and seeing if it changes the symptoms.
Because the anti-sink sphere seems to do nothing useful, it's often neglected despite its important but largely hidden functions.
froggy
- (Donor 2026)
- x 4
Xantia suspension
Thanks Jim
Terry
