Getting there
c.morewood
x 55
Getting there
Unread post by c.morewood »
This year I've been spending a lot (time and money) in getting my 220k Xantia back to a normal state as there have been a lot of little niggly things needing attention as well as some major ones.
So far this year I have replaced both bottom ball joints, by means of hub transplants, replaced 4 nearside wishbone bushes (3F failures and 1 precautionary rear), both droplinks and both outer trackrod ends.
I've now got to the stage where I'm geting severe vibration under braking at speed, but not at low speed from the nearside front.
I had a look at the disc yesterday, sure enough it was uneven, I marked it off with a black marker to show the proud side and removed the disc to check whether anything had got under the disc when the hubs were done.
I couldn't see anything, but when I was in the process of checking the disc, I noticed as the engine was turning over in 1st gear that the driveshaft was not rotating true and had a 2-3mm distortion on it.. it doesn't look bent.. So my questions to this knowlegeable forum are:
Is this normal for a driveshaft not under load?
What would cause the disc to warp?
And could these issues be the cause of the front wishbone bush failures?
Thanks,
Chris.
PS despite this I'm getting about 58mpg at an average speed of about 50 mph on country roads with a range of about 900 miles so the old lady isn't ready for the scrapheap yet :D
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
x 1240
Unread post by Peter.N. »
Hi Chris
Discs do warp, generally due to over enthusiastic braking but generally the brakes seem to work allright. The run out on your shaft could be due to wear on the inner joint or even the outer on, which ends moves most?
Keep it going - better the devil you know ...
c.morewood
x 55
Thanks Peter... My thoughts exactly.. and she's not exactly a devil... just a middle aged lady, requiring a little TLC.. I just can't quite get my head around fixing one problem only for another to appear within a week.. I'm sure there must be a common cause, but I'm not sufficiently experienced with this area of the car to fgure it ut for myself.. thats why this forum is so great the members are real experts and so helpful
'94 Fiat TipoTd 40K
x 1240
Citroens are like that but once you have fixed everything they can be very reliable - When I say fixed everything, I mean everything that actually stops it from going :D
