when the climate control system is active on my synergie i loose coolant, but if i shut the system off i don't . i always thought the 2 systems were completely seperate so they shouldn't effect each other.
any ideas as to what my problem could be???
strange problem
- x 1055
spider
- x 77
I'd suggest its water too, we used to get a lot of people come back with their first car with A/C (especially in hot weather) as they thought it was leaking.
A drip drip of water (assuming it is water, and not coolant) is normal as the moisture is taken out of the "conditioned" air and it has to go somewhere, usually a drain pipe fitted underneath.
Andy.
