Toolbox
Gregg1100
- x 5
Toolbox
Hows this for a toolbox, and look what is was sold for;
http://cgi.ebay.co.uk/290569983872
Greg
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
spider
- x 77
- x 8453
Onlinemyglaren
- x 5688
Gregg1100
- x 5
Toolbox
Apparently someone in the ASK A QUESTION bit asked if the seller would split, cos he only wanted a 2mm allen key.
Gregg1100
- x 5
Toolbox
Also this was asked,lol;
Q: I will happily put in a massive bid to win... but only if the set includes a two-tone left handed cornflake magnet? Can you please confirm this is the case or not. Thanks
addo
- Sara Watson's Stalker
- x 95
- x 8453
If Snap-On did make anoraks then they'd be seriously good and last a lifetime!
The rule is to have enough high quality tools to do the the work you do on a very regular basis and then slowly add specials as and when you need them. I've been doing that for 30 years now and there's still odd things I find I need. Namely, an enormous 3/4 drive breaker bar and some sockets to go with it and an 11mm crow's foot.
Actually, that's quite true Adam, that kit has far more than anyone would ever need for any conceivable task in any conceivable situation. I'm amazed the seller didn't split it into manageable lots...addo wrote: What a massive waste of money the whole thing is...
addo
- x 95
Toby_HDi
- x 3
CitroJim wrote:...there's still odd things I find I need. Namely, an enormous 3/4 drive breaker bar and some sockets to go with it...
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Xaccers
- x 188
Is a 600mm long one big enough for the breaker bar?CitroJim wrote:If Snap-On did make anoraks then they'd be seriously good and last a lifetime!
DIY sphere tool
DIY sphere tool
addo
- x 95
Xaccers
- x 188
I was referring to the breaker bar that Jim needs to replace, if memory serves it was less than 60cm.addo wrote:Barely. It's the breaking torque you need to overcome, not the 100 foot-pounds or whatever your offending part may be officially tightened to.
Overcooking it with a short bar is a good way to tweak your back - better to have excellent leverage.
DIY sphere tool
DIY sphere tool
- x 8453
And a good way of shearing off the bolt tooaddo wrote: Overcooking it with a short bar is a good way to tweak your back - better to have excellent leverage.
Ignore that one Xac... I broke that one years ago on a 205 hub nut. I replaced it with my three footer but keep the old broken one as it's useful as a pry bar and a short lever for my jack in confined spaces...Xac wrote:I was referring to the breaker bar that Jim needs to replace, if memory serves it was less than 60cm.![]()
I never throw away any broken tools as they have their uses...
The one I really want is getting on for five feet long with a 3/4" drive 35mm socket at least for making easy work of hub nuts and lower swivels
I could do with a longer 3/8" drive breaker though. My little foot long one is a bit girly for some jobs and one half as long again would be most handy. I had to extend it yesterday to release Juliet's auxiliary belt tensioner...
- x 1953
That's when I reach for my five foot length of gas pipe to slip over the handle of the breaker bar.addo wrote:better to have excellent leverage.
Nothing has remained unmoved by this combination so far although my son-in-law managed to put a bend in the gas pipe doing the hub nut on his Synergie!
