2.0 Hdi 110 bhp remap ?
bxzx16v
x 34
Unread post by bxzx16v »
Has anyone had a remap or got a tuning box fitted to their hdi , was wondering is it worthwhile or not , just a bit conserned about reliability and the extra stress on the mechanicals etc , thanks
Mark
wright
Unread post by wright »
I have a tuning box on my c5 for the last 14k with no problems, its got great low end pick up, I would get one again, I did do my clutch but it was the original one with 160k on it so I don't blame the tuning box, i like the tuning box as opposed to remapping because I can take it off and put it on my next car or just sell it and get some money back
02 C5 2.0 hdi 110
i3
Unread post by i3 »
can you get this tuning box for a 2.1?
bxzx16v
x 34
Thanks for that , might look into a tuning box , what make is yours ?
Mark
wright
the one i have is called tuning box, you can see info on www.tuningbox.com
02 C5 2.0 hdi 110
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I also have a tuning box on my 110bhp Xantia, done 28k with it now. still strong as ever. The extra performance gained is also very impressive!
I would recomend one, it appears to not affect my fuel consumption at all, remaining around the same as normal..
Paul
A very sad...
1994 XM 2.1 d auto
steelcityuk
Unread post by steelcityuk »
I've had remaps on both my C5 and the A170 CDi. Very impressive results. I bought the maps from a tuner and flashed them onto the ECU myself. Just stay away from anything that is supplied without you first having to send them your existing map.
Steve.
not applicable
i3
Unread post by i3 »
does anyone have a map for the 2.1? not at 110, but the upgraded map at 135ish?
steelcityuk
You can't remap a 2.1, Epic or Bosch. The Bosch is purely mechanical and the Epic isn't a fully electronic injection system. There used to be an add on available for it thought, some member somewhere had one.
Only HDi's are remappable.
Steve.
not applicable
x 1908
I don't think you can get a tuning box for a 2.1 as it isn't under computer control.
Unless you mean the 2.2 engine?
i3
Unread post by i3 »
thanks Steve,
so if those websites advertising the 2.1 remap service, are they just basically scams?
steelcityuk
Well if it's the PSA XUD11 engine then I think they don't know what they are selling. There's loads of 'experts' selling on tuning files that's come from who knows where. Such maps usually turn off any immobiliser features to allow them to be universal, make your engine smoke like a demon and/or adjust the wrong parameters with sometimes major consequences. You really need a 'real' reference before buying such services.
Steve.
not applicable
citroenxm
Fallen Hero
x 70
Depends on the Fuel System..
Early 2.1 engines in the XM are Mecanical ONLY up to 1997..
Then when it was fitted to the Xantia it gained Lucas EPIC semi electronic, which have an ECU that may be "Chippable" but they are not completely electronic.. So it could be a possiblity to Chip a 2.1 LATER engine from 1997.
Paul
A very sad...
1994 XM 2.1 d auto
i3
Unread post by i3 »
So that's my engine then... :)
bxzx16v
x 34
Pretty sure a company called Tunit do a box for the 2.1 td as I was considering one for our old Xantia a few years back
Mark
