How do I replace this rubber thing?
Ozzie Kuma
Unread post by Ozzie Kuma »
Can someone tell me how to replace this rubber thing please....(if it is possible that is). I assume it is there to prevent "bottoming out", don't know what it is called.
98 Xantia V6 MK2
95 Xantia VSX
addo
Sara Watson's Stalker
x 95
Unread post by addo »
That is a "butée élastique" or bump stop. P/N 0000516655
I remember noting yours were a little past their best - mine are not in good shape either!
General remedy in such cases is to buy the newies and then eyeball them to work out how best to remove/replace. In this case, they appear from the images to just wiggle in from below.
They are $94.22 each here (should that be ouch?), or $120 posted per pair, from a European supplier. One of the chaps here might be able to get them cheaper ex-UK, as my German contacts charge like wounded bulls for postage on small items.
Ozzie Kuma
thanks mate,.. are you getting my messages about the $$$ for the core?
Tell me how to get the $$ to you...
98 Xantia V6 MK2
95 Xantia VSX
Dommo
x 20
Unread post by Dommo »
Bump stops over here are £11.02
I should get some on order, mine are buggered! Posting over to you can't be much if you want me to look into it?
Ozzie Kuma
Yes please , get 4 please,.. not got Oz $ to UK before , but I get $ to Japan often can't be much different.
No rush, much appreciated.
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
That sounds the go; "Royal Mail Small Parcel" is the tagline for affordable postage.
I use PayPal a lot to send small sums of money overseas - seems the easiest way at present, although I hate the company with passion.
Will be in touch about the heater bit; just haven't downloaded my photos to help explain its installation as camera went flat.
Dommo
x 20
Did you want four ozzie kuma, or you want 2 and addo wants 2??
Are you two fairly local to eachother - ie would it be worth sending one package that you to can then forward a pair on to the other?
Ozzie Kuma
Dommo,
I got two Xantia so I though I would do them both,.. but just been under it now & they are fine,.. on the older car (??? very strange)
So only TWO for me ( sorry ) but if addo want two as well, send the FOUR to me & I'll get then to addo,.. ie .. one parcel..one money transaction,.. I owe addo anyway.
That ok by you addo ?
98 Xantia V6 MK2
95 Xantia VSX
addo
x 95
I'm not sure if wagon ones are the same - need to confirm and also estimate the lifespan remaining on mine (if any!).
Dommo
x 20
Any updates Addo?
addo
x 95
Sorry Dommo - been smashed with work until a day or so back. It's presently too wet for looking under my car. :cry:
addo
x 95
Dommo - is it going to be too much a chore for you to tackle this mission at present? Please advise.
Dommo
x 20
Sorry forgot to let you know what is going on.
They are on order. There was a bit of a faff as to which to order as apparantly there are two types, if you could PM me the exact part number you want I can be sure it's the ones I've got on order :lol:
addo
x 95
My RPO is 8146, you could probably order two pair off that. P/N 5166 55
Still waiting for payment instructions.
Ozzie Kuma
I have no idea of the part no. for mine ?? what is the damage ($$) approx ?
Many thanks for the trouble.
98 Xantia V6 MK2
95 Xantia VSX
